Go to Post I miss the years when game speculation was based on an actual hint released in the form of unintelligible strings of numbers - tcallan [more]
Unread 24-12-2011, 07:43
Ninja_Bait's Avatar
AKA: Jake Potter
FRC #0694 (StuyPulse)
Re: pic: Other Swerve Drive I designed while being bored
Originally Posted by Gray Adams View Post
How else could you justify that much chain
Who said you need justification for chain?
Nice design, though. My only qualm is that it looks a little heavy; you probably don't need that much aluminum for it to work.
Unread 24-12-2011, 14:42
MattC9's Avatar
MattC9 MattC9 is offline
It looks like every piece of AL is needed, keep in mind that you have 6 modules and you need support for each and every one of them. Here you need a frame, 6 module mounts, 6 modules, transmission mounting, and sprocket and chain hardware. Swerves are heavy by nature, so in comparison to a regular swerve this one will be about 50% more heavy than a 4wheel swerve.
p.s. to the OP, great job I like how this one can shift! I have also seen the 4wheel version of this baby and it look great! keep up the good work.
Unread 24-12-2011, 14:50
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
How heavy is this design?
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 24-12-2011, 17:18
Garret's Avatar
Garret Garret is offline
AKA: Garret Smalley
Thanks for the compliments.
With Battery and electronics this model weighs 70.5 lbs. This picture makes it look as if it has a lot more frame members than it really does. The frame itself weighs 7 lbs and is made of welded 1x1x1/16" Aluminum tube. All of the other parts including the modules are bolt on.
We already had these modules machined (they are the same as our 4 wheel swerve) which is why I used them in this model.
7 Years of FRC
Unread 24-12-2011, 17:52
MattC9's Avatar
1/16th? to hold up that whole thing? I know of weight reasons why you would use 1/16th but isn't this system taking allot of stress? I wouldn't even use 1/16th on a simple 6wd... just my opinion.
