Go to Post Most of our old robots have been scrapped for parts. Our Chairman submissions are still read every year by the whole team. - N7UJJ [more]
Unread 24-12-2011, 13:45
JackS's Avatar
JackS JackS is offline
Sideline Observer
no team (EWCP)
JackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond repute
Re: pic: CAD Chassis
Originally Posted by MattC9 View Post
That is a beautiful render... but one question how do you tension the chain?
We are actually using 15mm belts with center to center spacing, which does not need tensioning. One belt run is actually inside of the tube, and the other belt run is outside of the tube, and you can see those pulleys on the front wheels.
Jack, is this an iteration of your 2011 drive? http://www.chiefdelphi.com/media/photos/36832
Yes and no, there are a lot of changes (wider belt, different size tube, gussets instead of welding, AL not PVC belly pan, moving to two belts, different reduction, and different bumper mounts) that make this significantly different from last years chassis. It is still without bearing blocks and a few other staples of the standard 254/973/1323 WCD, but it is closer to that design than ours from last year.
[2009-2014] FRC Team 2791 - Shaker Robotics
Colgate University
'16
