Go to Post Never quit, never give up, never say die! - Cascade [more]
Unread 25-12-2011, 04:15
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: WCP: AL Gears?
Originally Posted by Mk.32 View Post
Do we have any numbers on the weight saving with the alum gears over the AM ones? For say a SS or TB.
A pound or two would be very nice.
Aluminum is 35% of the weight of an equivalent volume of steel.
In 2007 we saved roughly two pounds per transmission over the use of steel gears. We also used delrin sideplates, piston mounts, and shift shaft-piston bearing blocks so the savings due to aluminum are probably a little less.
2001-2004: Team 100
2006-Present: Team 254
