Go to Post It's all about bragging rights, awards, and pushing the envelope, not necessarily winning or practicality. - ahecht [more]
Unread 01-01-2012, 21:45
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: pic: NanoShifter
Originally Posted by SuperNerd256 View Post
The way I see it, depending on the weight of these things, and the do look light, one could use 6 of them, one per wheel, or at least 4 of them, 2 on each side, making a very powerful drivetrain.
Excellent gearboxes for mecanums, however I see a lot more use in these than mecanum wheels.
If you used six, you would have to have six motors in your drivetrain. Also, if you used 2 on each side for a non-omidirectional drivetrain, you would save weight by simply using one transmission. The power would be the same since the motors supplying the power are the same as they would be with two gearboxes.
I agree that there are more uses for them than mecanum, they could be useful in swerve and omni-drives. But they could also be useful in non-drivetrain applications like shooters.
