Go to Post Robots can be fixed, glory is forever - Brandon Holley [more]
Unread 01-01-2012, 21:48
Andrew Lawrence
Re: pic: NanoShifter
Originally Posted by PAR_WIG1350 View Post
If you used six, you would have to have six motors in your drivetrain. Also, if you used 2 on each side for a non-omidirectional drivetrain, you would save weight by simply using one transmission. The power would be the same since the motors supplying the power are the same as they would be with two gearboxes.
If 2 of those weigh less than one of the standard transmissions, it'll be less weight no matter what. Plus, you gotta admit: Just by seeing it you wanna use it on a robot.
