#19
Re: pic: NanoShifter
If the press fit between the shift gears and their bearings was light enough, and the diameter of said bearing on the low gear side was less than or equal to the diameter of the dog AND less than or equal to the diameter of the hole for the flanged output bearing, this would work:
(A quick check of AM shows that the dog gear has an OD of 1" and the low gear uses an R8 bearing (1.125") - this would work possibly) 1. Insert the rear bearing (piston side) and press it in 2. Insert the two shifted gears into the tube 3. Assemble the shift shaft with the bearings, dog, and other bearings 4. Insert through front (output side) of transmission, pressing bearings into gears as you went 5. Press on output bearing from the outer side - If I am correct, this will be fine as the wheel will hold the bearing on 6. Assemble the cluster shaft like the current way AM does it --One bearing is flanged and inserted first --All of the gears are inserted and the shaft is inserted from the outside, through all of the gears into the inner bearing --The outer bearing is inserted, and the two screws hold it 7. The CIM motor is the easiest part. 8. Assemble the shift linkage - This is standard AM shifter stuff |
