Go to Post Multiple event winners are what drive me and my friends to be better and achieve more. - Akash Rastogi [more]
Unread 02-01-2012, 12:10
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
pic: Team 2220 traditional 6 wheel drive
Center drop: 1/8"
I know there are a couple problems with it already. Using the extended output shaft, we still don't have enough room in the wheel well to run 2 loops of chain. Other than machining a longer outputshaft, are ther other easy fixes? Also, I am not completely familiar with how to use some of the stuff from Andymark: do I need to use 2 hubs on the driven wheel, or do I just need a hub on one side? If I only need one hub, I think we can make the chains fit, but it will still be close.
Are the gussets enough to keep it square? Are there any other problems I should be aware of?
Unread 02-01-2012, 12:40
Andrew Lawrence
Re: pic: Team 2220 traditional 6 wheel drive
Nice! Looks.... traditional. :|
Great simple 6 WD! Looks very robust.
Unread 02-01-2012, 12:53
CNettles11's Avatar
CNettles11 CNettles11 is offline
AKA: Chris Nettles
FRC #3502 (Octo-Pi-Rates)
CNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the rough
Could you get away with flipping the outside C channel pieces and running the chain inside of them?
Unread 02-01-2012, 13:04
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Originally Posted by Alex.q View Post
Center drop: 1/8"
We have never used more than one AM hub per AM wheel. We have used plaction, plastic omni-wheels and mecanum wheels with this setup and have never had a problem.
Unread 02-01-2012, 14:13
Ninja_Bait's Avatar
AKA: Jake Potter
FRC #0694 (StuyPulse)
You could use the 6" performance wheels, which already have the keyed bore on them.
