Re: pic: Unobtainium 6wd - Cantilevered, Dead-Axle, Slot-Tensioned Drivetrain
Is the idea here that the bolts are threaded into the frame member or are they through-bolted with a nut on each side?
My gut reaction is one of concern that the bolts will unscrew themselves, but maybe that's unwarranted. Edit: Nevermind; missed that this is a shoulder bolt. Last edited by Madison : 01-04-2012 at 12:00 AM. |
This is very nice and simple but I'd be worried about the forces that cantilevered load is putting on a very small amount of aluminum. Id guess that over time either the hole in the aluminum would oval out or the angle itself would want to bend below 90 degrees. You may want to run some CAD analysis, but with me this doesn't pass the sniff test.
The shoulder joint will definitely hold, but it has to be supported by the frame. With a single support point in just 1/4" of aluminum, it will likely just bend the angle aluminum and not stay horizontal. A box extrusion will solve this problem by providing two support points for the bolt and not deforming under the loads we're talking about.
I'm pretty sure this would hold, over time you would probably see the slots warp a bit after repeated use. My main concern would be the flex in the main angle bar. The middle wheel would likely flex a decent amount when it had weight on it, if there wasn't any extra cross support in the middle of that system. I could see it flex enough in this configuration that it could almost negate a 1/8" center drop. But that flexibility could be interesting for a mecanum drive...
Interesting design, it might work for some games, but not for others.
We built a cantilevered dead axle drivetrain on our 2008 robot, using 1/2" threaded rod for the axles, and 1/8" thick 1x4" pultruded fiberglass for the frame members. We had an adjustable chain tensioner instead of slotted holes. It worked fine for the Overdrive game, since the playing field was flat and most of the action was driving laps. http://www.chiefdelphi.com/media/photos/29697 |
![]() Quote:
You might want to try heavy-duty all-metal locknuts (the ones with the elastically-deformable bore), or high-strength steel nuts and threadlocker. Torque them to the limit specified by the manufacturer. Given the shoulder bolts, you'll probably need an unusually-strong Allen wrench to make this happen. That's the only way I could see this holding tightly enough in a slotted hole.
Consider http://www.mcmaster.com/#92501A030 or http://www.mcmaster.com/#93591A200, for example. |
Stover lock nuts, you mean?
I suggest you might want to find or figure out how to make a more substantial washer. Our design used large hex flanged nuts. You might be able to do this too, and use 1/2" fine thread threaded rod for the axle as we did. We used two jam nuts to retain the wheels, but this required that whoever was working on the robot needed to know not to tighten the nut too much! ![]() Last edited by MrForbes : 01-04-2012 at 12:37 PM. |
And here I thought this was an original idea .The flanged Stover lock nuts look pretty nice, and I think they would go a long way to improving the design. Placing one on either side of the plate instead of the washers, upsizing to a 1/2" shaft of fine threaded rod and two jam nuts to keep the wheels from falling off seems to be the direction I'd like to go in... and then an FEA. Questions: Did your wheel bearings rest on the threads of your threaded rod? If so, any concerns with this? Excessive play? Still worth the trade-off IMO, but curious nonetheless. Did you have frame flex issues at competition weight? Did you have to add more support to your C-channel side rails to prevent them from twisting, resulting in negative camber? Was that a typo, or was your fibreglass C-channel really only 1/8" thick? Thanks all who posted in this thread who shared their comments and concerns (yes, that includes you Dr. Joe!). Really, as a programming and electronics guy, if I can't get the mechanical guys to cringe at least once or twice a day, I'm not doing my job right .Quote:
#10
Again, this robot was designed for a specific game, and worked well for that game. The 2009 robot we made of wood was even more unconventional, and also worked very well for the game it had to play. The steel robot we made the following year didn't work as well, it had cantilevered axles, but because of the bumps it had to traverse, the axles bent significantly during the competitions. |
#11
Actually, my original concept called for 1/2" shoulder bolts in a slightly different configuration. I intended to have the shoulder portion of the bolt pass through the frame, and tighten the entire wheel assembly against the frame with very thick washers.
The thread of a 3/8" shoulder bolt is 5/16"-18, which in my opinion is too small to be supporting this kind of cantilevered load. Thicker washers would help some, but the thread length is only 1/2", so you don't have much to work with, probably not even enough for a heavy lock nut. I think what you have shown could work with a larger shoulder bolt, but it looks like squirrel's method with 1/2" threaded rod would be simpler and stronger. And fine thread really helps to get things tight. Another issue is bending of the frame itself. Putting a cross bar at the top of the angle next to each wheel would help a lot. It could be a thin wall tube with a small threaded rod running all the way through. |
#12
There is a lot there to love.
A lot that is cringe worthy as well, but overall, a nice effort. Got me thinking... ...How can I use this? Maybe there is something there... Thanks! Joe J. |
#13
Cantilevered shoulder bolts can take a lot of load. I used them in an FSAE car suspension rocker that saw around 5,000lbf. The trick is to get the shoulder supported and eliminate bending stresses from any threaded portions. The only serious issue I can see in your design is how the shoulder bolts are connected to the rail.
![]() In this picture near the left-hand edge about 1/3 of the way down you can see where we used a 5/8" (1/2"?) shoulder bolt on the suspension rocker. About half of its length passed through a steel mounting point, then went through a needle bearing in the rocker, and was captured with a nut on the inside of the car. We sandwiched thrust bearings on either side of the rocker so we could clamp everything down very tightly yet still spin it by hand. I hope you find this useful *cough* needle bearings in wheels *cough* ![]() |
#14
Thanks. |
#15
Here is the thing. For those who have been doing this for a long time, design is an emotional experience. I believe that we humans utilize our emotional brains to sort through complex space of possible solutions. Our emotional brains are just really good at searching through complex system interactions. So... ...When I see something obviously awesome, I often laugh (I recall the first time I looked up in the GA Dome I laughed and laughed as I realized how cleverly the designers used hoop strength and tension members together with compression columns to raise the higher and higher tent poles over that beautifully clear interior). When I see something not so awesome, I feel it in my stomach. So... ...what do I think is less than awesome in the design? I think it boils down to two conflicting functions of the 1/4 angle. When I first see it, it seems both not strong enough and too strong at the same time. It doesn't seem strong enough to be the sole mount for the cantilever axles. While at the same time the 80-20 and 1/4 angle seem pretty heavy for what they are doing. The thing about emotional brains is that they can be wrong. We educate our emotional brains the best we can but they sometimes point us in the wrong direction. I would have to do the calculations to know (and I haven't). So... ...that is probably the numb of what I was getting at (that and the connection between them draws my eye as well). Let me close by saying I was too harsh. There is a lot to like and a lot that I would change. But a very interesting effort. Joe J. |
