Go to Post If you look at where you have come from you can often tell where you are going. - Turtlecoach [more]
Go Back   Chief Delphi > Technical > Motors
Unread 07-01-2012, 20:09
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: Simple Motor Calculator
I have updated the motor calculator for the 9015 (am-0912) and PG71 (am-0914) 2012 motors.
The app is now 32-bit so it should now run in 64-bit Windows (XP & 7).
I am re-working the floating-point error trapping and will update again when that is done.
Enjoy.
