Go to Post These are threads, and they are what hold the community together...so CD must be a threaded fastener right? - Andrew Blair [more]
Unread 08-01-2012, 11:22
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Re: pic: Well Now What?
Originally Posted by Billfred View Post
I wouldn't bet on that--it doesn't look like that ball would have tripped the sensors to count it.
I don't know about the sensors, but points are counted for the balls once they fully pass through the hoop by G38.
Originally Posted by G38
Alliances will be immediately awarded points for each Basketball that passes completely through a Hoop as follows:
[Table with Top/Middle/Bottom Scores]
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 08-01-2012, 11:23
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
But wouldn't you then get a penalty for not returning it? :/
Unread 08-01-2012, 11:34
Basel A's Avatar
AKA: @BaselThe2nd
Not at all! Take a look at G31. The ball never makes it to the corral, so it never has to be "removed immediately." There could potentially be 6 balls held by inbounders and an additional one stuck without penalty.
Personally, I'd call this a field fault and replay the match or simply fix it now to stop it from happening again.
Originally Posted by G31
Only Inbounders may contact Basketballs; each Inbounder may hold a maximum of two Basketballs. During Teleop, Inbounders must remove Basketballs from the Corral immediately upon arrival. All Basketballs in the Alliance Station must be held by Inbounders once removed from the Corral.
Violation: Foul
-Paul Copioli
Unread 08-01-2012, 12:47
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
Can somebody just verify for me that in this picture that ball got stuck in the return chute just before it gets counted? What I see in the picture (or what I think I see) is the ball was never scored (it never went through the hoop) it just missed the hoop and got stuck underneath the goal just above where the balls return to the corral.
D5 Robotics: Member since 2007
Drive Team Coach, Design Mentor
Palmetto Regional attendee 2007-2011
2009 QF, 2010 SF, 2011 SF
Unread 08-01-2012, 13:19
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
I predict a return of the pokey sticks from 2006...
Unread 08-01-2012, 13:23
EricLeifermann's Avatar
EricLeifermann EricLeifermann is online now
Taking some personal time
EricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond repute
The ball didn't go in the hoop and return chute in this picture. The ball is sitting on top of the chute
2002-2005 Appleton East High School: Team 93
2005-2011 Michigan Technological University: Team 857
2012-2016 Wave Robotics Team 2826
Unread 08-01-2012, 15:41
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Correct, I had to shrink the image because of CD's size limit. The ball is sitting on top of the return chute just under where the hoop is mounted.
Again this was my second shot and I saw a few others land in the same area during the morning.
Brendan
1058 PVC Pirates 2016 - xxxx
Unread 08-01-2012, 15:49
ratdude747's Avatar
AKA: Larry Bolan
Brendan
a legal starvation strategy?
Unread 08-01-2012, 15:52
AKA: Brendan Browne
I'd rather put them in my lane than do that. 18 balls means if each robot has 3 there are none on the field or inbounders.
Any ball you get is a gift so starving in this game is realistically collecting your 3.
Unread 08-01-2012, 16:05
Captain Slacker's Avatar
Captain Slacker Captain Slacker is offline
FRC #0571 (Team Paragon)
Captain Slacker will become famous soon enough
A ball doesnt count unless it makes it through the entire hoop. this hasnt completed the motion.
Who Rocks This House?!
PARAGON!!!
Unread 08-01-2012, 16:14
AKA: Brendan Browne
This isn't a scored ball, this is a stuck ball on top of the ball return and the only way to get it down is through a hole.
Unread 09-01-2012, 00:01
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Balls also got stuck between the netting and the backboards. I was assured by FIRST staffers that field reset crews will have implements to dislodge balls that get stuck like this during a match. Train your human players not to interfere with these balls, it is a penalty. Leave it to the field crews to get the balls reintroduced to play.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 09-01-2012, 02:33
Aren Siekmeier's Avatar
on walkabout
The alley is not impassable by the opposing. It is only opposing robots in the opponent's alley that you must avoid per <G28>. So if there are no opposing robots on your offensive side, you can quite safely and immediately retrieve any balls dropped out the feeder slot (keeping in mind human players may hold six in total).
Unread 09-01-2012, 08:11
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud of
This is a stuck ball. It may take the ball out of play, but otherwise, there is no problem. Every robot on the field now has to deal with the situation of having only 17 balls to score with. If the field crew can deal with it, they will, if not, then everyone plays with fewer balls, but no one on the field gets an advantage by that.
Same as when tubes got stuck on nets and poles last year.
Dr. Bob
"Chairman's award isn't about building a robot; every team builds a robot."
Unread 09-01-2012, 13:06
AKA: Brendan Browne
Sorry, I too often have to catch myself confusing the alley for a feeding lane. Too many clauses to me. I'm too used to red tape for red alliance bots only and blue tape for blue alliance robots.
