Re: pic: Well Now What?
But wouldn't you then get a penalty for not returning it? :/
Personally, I'd call this a field fault and replay the match or simply fix it now to stop it from happening again. Quote:
Can somebody just verify for me that in this picture that ball got stuck in the return chute just before it gets counted? What I see in the picture (or what I think I see) is the ball was never scored (it never went through the hoop) it just missed the hoop and got stuck underneath the goal just above where the balls return to the corral.
I predict a return of the pokey sticks from 2006...
The ball didn't go in the hoop and return chute in this picture. The ball is sitting on top of the chute
Again this was my second shot and I saw a few others land in the same area during the morning. Brendan |
a legal starvation strategy?
I'd rather put them in my lane than do that. 18 balls means if each robot has 3 there are none on the field or inbounders.
Any ball you get is a gift so starving in this game is realistically collecting your 3. |
A ball doesnt count unless it makes it through the entire hoop. this hasnt completed the motion.
#10
This isn't a scored ball, this is a stuck ball on top of the ball return and the only way to get it down is through a hole.
#11
Balls also got stuck between the netting and the backboards. I was assured by FIRST staffers that field reset crews will have implements to dislodge balls that get stuck like this during a match. Train your human players not to interfere with these balls, it is a penalty. Leave it to the field crews to get the balls reintroduced to play.
#12
Take off your shoe and thwack it with that?
#13
The alley is not impassable by the opposing. It is only opposing robots in the opponent's alley that you must avoid per <G28>. So if there are no opposing robots on your offensive side, you can quite safely and immediately retrieve any balls dropped out the feeder slot (keeping in mind human players may hold six in total).
#14
This is a stuck ball. It may take the ball out of play, but otherwise, there is no problem. Every robot on the field now has to deal with the situation of having only 17 balls to score with. If the field crew can deal with it, they will, if not, then everyone plays with fewer balls, but no one on the field gets an advantage by that.
Same as when tubes got stuck on nets and poles last year. Dr. Bob "Chairman's award isn't about building a robot; every team builds a robot." |
#15
