Go to Post Totally agree on the fact that legal strategies are... legal. - Kevin Sevcik [more]
Unread 13-01-2012, 13:06
davepowers's Avatar
davepowers davepowers is offline
Currently dreaming about robots
AKA: Danger Dave
FRC #1687 (Highlander Robotics)
davepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud of
Re: pic: We've got balance, how bout' you?
Originally Posted by SuperNerd256 View Post
Oh shnap! Gus got balance! Now let's see you do that with all three robots being controlled, not just placed on a bridge!
Who said they were placed? ;]
Originally Posted by BrendanB View Post
What are the dimensions on those robots on that bridge? Are there any supports/weights added to those robots? Did you drive these robots onto the bridge or did you place them?
Very impressed to see this!
37 inches long for all of them. There are no supports or weights. And that's for you to decide. ;] We'll have some fun stuff up tonight. Thank you!
All it takes is for two of the three robots to have identical CGs. And none of them get to move.
I'd still say wide is the way to go.
Who said that the two end robots have the same CG's? I'm fairly positive they both aren't exactly the same anymore, especially with lack of minibot ramp, paint, and electronics board configuration, they are fairly different now. I do agree with the none of them get to move though, regardless of weights and CG.
Originally Posted by Flak-Bait View Post
Nice! Do you have any clue about how much room for error you have when balancing the three robots?
Fairly close to none.
Originally Posted by JamesCH95 View Post
Could all three robots drive onto the bridge? Even if you just pushed them on I'd be curious.
Yes all three robots could drive onto the bridge with a little frame scrape, but did we drive them all together? You'll just have to wait and see.
Originally Posted by Peter Matteson View Post
Does your ramp actually act like the one in the field tour video?
As close as we could get it. A little tip for anyone building the bridge is you're going to need to add weights to each end. And quite a bit of it too.
-D
David Powers - Deans List Finalist - WPI 17' - Bleed True Clothing
1999-xxxx FRC228, GUS Robotics Inc.
2013-xxxx FRC1678, Highlander Robotics
