| Thread Tools |
Rating:
Display Modes |
#16
Re: paper: You can do CAN: CAN on a Budget
The pinout of the adapter in this years KoP is different.
These are the colors of the wires that should go to the pins of the DB9 connector: Blue -> Pin 2 White -> Pin 3 Yellow -> Pin 5 If you use the resistor, it goes on red and green (I haven't found it necessary) The black wire can be ignored |
#17
Anybody else able to confirm the pinout? Unlike the db9 adapters from mono price these seem to use the correct color/rj12 color scheme. Unless I hear otherwise, I will promptly edit the document to reflect that. Last edited by ratdude747 : 15-01-2012 at 15:39. |
#18
Good and bad news:
good- all documents have been updated, including the pinout chart bad- I was only able to upload the .pdf version; the other versions are no longer allowed for upload. I will see if there is a way around the issue, as the editable versions were actually seeing downloads before the filetype ban. what was changed: - pinout charts updated to include the 2012 pinouts (thank you ggorsuch for the tip!) - changed some image formatting in the serial splice cable section - added references to the 2012 adapter - made some spelling fixes - converted the document to Justified alignment to make it look more professional. as always, comments and suggestions are always welcome. EDIT- Weekend/build season wise, today happens to be the 1 year anniversary of the document's original writing. Last edited by ratdude747 : 15-01-2012 at 16:56. |
#19
The upload issue has been fixed. All files can be downloaded again.
Also made a few grammar repairs. |
#20
I have uploaded an updated version:
- Images converted to lossless JPG compression in the .pdf version. - Added my new personal logo to the end of the document. FYI, the revision date didn't change since there text is still the same. |
#21
Question: I noticed that IFI is now the producer of the Jags. Has the sites for where BDC-comm and the firmware changed? If so, I'll update the paper to reflect the change (as long as serial Can is legal, I'll support the paper).
