Go to Post OPR will not get you to Einstein - Paul Copioli [more]
Unread 15-01-2012, 17:43
davepowers's Avatar
davepowers davepowers is offline
Currently dreaming about robots
AKA: Danger Dave
FRC #1687 (Highlander Robotics)
davepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud of
Re: pic: We've got balance, how bout' you?
Originally Posted by EricLeifermann View Post
Being secretive about good ways to get 3 robots on a bridge and balance it isn't going to help you in the long run because if you are the only team that can do it your screwed because you need 2 others to do it. So why not share so more teams can think about it and decide if they want to go the same rout? Helping everyone is really helping you this year....
I have to disagree, if a team has a way to balance three robots on the bridge that is extremely successful, it would be in their best interest to keep that a secret. Remember now this is still a competition. And if said team that has the good idea decides to use that in a competition, then I'm sure they will pick the teams that can be used in with idea and they can let the cat out of the bag and inform the other teams in your alliance when it counts.
-D
David Powers - Deans List Finalist - WPI 17' - Bleed True Clothing
1999-xxxx FRC228, GUS Robotics Inc.
2013-xxxx FRC1678, Highlander Robotics
