Go to Post Take what you have learned, build on it and share it. Others will do the same. Enjoy the journey. - Bertman [more]
Unread 16-01-2012, 13:20
Ninja_Bait's Avatar
AKA: Jake Potter
FRC #0694 (StuyPulse)
pic: Drivetrain vs. Drivetrain
Unread 16-01-2012, 13:23
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: pic: Drivetrain vs. Drivetrain
Live or dead axles?
What is your wheel bearing plan?
I think when you work this out the sheetmetal will look more attractive that the 1x1 box.
Also bridge the front of the robot together in either design to stiffen it up. Right now both will flex and rack way more than you want to deal with.
Thank-you 294 & 67
www.bobcatrobotics.org
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
The top one looks cooler. If that counts for anything.
Every day is a new adventure!!!
Unread 16-01-2012, 13:28
Ninja_Bait's Avatar
AKA: Jake Potter
Thanks. We're going with live axles driving 6" pneumatic wheels with customized hubs. The bearings will probably be the AM 1/2" hex bearings.
The "sheet metal" is actually 1/8" C channel, because we lack the capability to do any sheet metal machining at this scale.
Because we will be putting in an acquirer in front, that gap will have to be bridged higher up in the frame. This is just the base right now, after all, and we do have a lot more to add to the superstructure.
And we're not really interested in cool if it takes too long to machine on a mill or it gets shred to pieces.
Unread 16-01-2012, 14:15
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Why don't you put the wheels inside the frame members? Thereby eliminationg cantilevered wheels and giving the possibility of removable "pods" in the case of a broken axle or such other catastrosphe.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 16-01-2012, 14:17
mtnDewey's Avatar
mtnDewey mtnDewey is offline
Starcat
AKA: Tyler Dewey
FRC #2993 (Megabots)
mtnDewey is an unknown quantity at this point
How are you planning on attaching bumpers? And if you are using 8 wheels to get over the bumps more easily, the frame is much too low.
Unread 16-01-2012, 14:28
Ninja_Bait's Avatar
AKA: Jake Potter
Cantilevered wheels will, in our opinion, be as easy to change as any other system. They also give us a wider trackwidth for turning. It will also be easier to work with the AM shifter like this, because we won't have to figure out a work-around for the wheel offset caused by the output sprockets. We are also considering belt over chain, so we are going with this design to avoid having to bolt pulleys to our wheels.
Bumpers will go on a lightweight frame above the wheels.
We are using another way to get the wheels over the bump, so we aren't concerned about the frame lowness. We've already tested the idea out and are confident in the drivetrain's ability to mount the bump.
Unread 16-01-2012, 17:01
pandamonium's Avatar
pandamonium pandamonium is offline
FRC #1836 (Milken Knights)
pandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond repute
I am curious... care to elaborate on what this mechanism is? At least a friendly hint?
Unread 16-01-2012, 17:11
Ninja_Bait's Avatar
AKA: Jake Potter
No.
Unread 16-01-2012, 17:23
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Very interesting designs. Three things to help make your decision, look at weight, strength, and feasibility to build. The first may be harder to construct. It looks lighter, however. Both look strong "enough."
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 16-01-2012, 19:29
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Your hint is: cheesy.
Sorry Jake, I just couldn't resist.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 16-01-2012, 19:33
Andrew Lawrence
Stealing something from the Poofs now, eh? I think I know what's going on now. Good luck 694!
Unread 17-01-2012, 09:35
lerikson's Avatar
lerikson lerikson is offline
Dj Mother May i
AKA: Lukas
FRC #1270 (Red Dragons)
lerikson will become famous soon enough
Send a message via Yahoo to lerikson
What is being used to assemble the frame you choose?
Official FRC Game Announcer & Master of Ceremonies for multiple events
Unread 17-01-2012, 09:42
Ninja_Bait's Avatar
AKA: Jake Potter
Riveted gussets.
