Go to Post Including the Kinect in the kit a parts is actually an evil plan. The programers are going to spend all their time playing with the Kinect. In competition the robot is just to sit there because it will not have a program. :ahh: - FrankJ [more]
View Poll Results: What weight is your team shooting for?
Will go out of way and add material to make the robot 120 lbs. 46 35.94%
Will shoot for 120 lbs, but will not necessarily make it. 26 20.31%
Going for the lightest robot possible. 25 19.53%
Not shooting for any specific weight. 26 20.31%
Other 5 3.91%
Voters: 128. You may not vote on this poll
Unread 17-01-2012, 12:06
Excellence is Bliss
FRC #0111 (WildStang)
Re: Robot Weight
Where's the "drill enough weight holes so we're barely under 120lbs" option?
Unread 17-01-2012, 12:09
MrForbes MrForbes is offline
Re: Robot Weight
We're shooting for making the "upper" part of the robot as light as possible, and we're not concerned about the bottom part. But we'll make sure it's less than 120 on bag day
Unread 17-01-2012, 12:21
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Robot Weight
It might not be a bad idea for a team to make their robot weight adjustable. Have some way to increase/decrease your weight by ~1 lb increments so you can match your alliance partners. "Our weight is adjustable. Robot A goes in the middle, we'll go opposite robot B and we've already calibrated our weight to 117lbs to match". Say that to a potential alliance before eliminations, and it could sway them to picking you!
Unread 17-01-2012, 12:25
crimsonjake's Avatar
crimsonjake crimsonjake is offline
AKA: Jake Westerberg
FRC #2526 (Crimson Robotics)
crimsonjake is an unknown quantity at this point
Re: Robot Weight
Another thing that could play a factor (a very, very small factor) would be the unequal distribution of weight upon each wheel.
i.e. the front of the robot has more weight on its wheels than the back.
Just to keep in the back of your mind!
Unread 17-01-2012, 13:40
Re: Robot Weight
We'll definitely do this, we will rearrange where things go to keep the center of mass centered between the front and back. Side to side is not too much of an issue....since we're planning a "wide" robot.
Unread 17-01-2012, 13:53
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Re: Robot Weight
As we understand this game, it's about speed. We'll keep our robot as light as possible. With a 35x27 frame and 8" wheels, we ought to be able to 'spin' on the bridge and change our orientation to perpendicular to the bridge, allowing our partners to climb up on the ends.
Hi!
Unread 17-01-2012, 16:10
Flimsor's Avatar
Flimsor Flimsor is offline
The Mad Cadder
FRC #1983 (Skunkworks Robotics)
Flimsor will become famous soon enough
Re: Robot Weight
We'll be shooting for lower than 120 but you always seem end up at the limit.
- 2013
Thinking outside the box implies you have limited yourself in the first place.
Robots
Unread 03-02-2012, 19:35
DarkByakko's Avatar
DarkByakko DarkByakko is offline
Winner
AKA: Sam
FRC #3461 (Operation P.E.A.C.C.E.)
DarkByakko is an unknown quantity at this point
Re: Robot Weight
Our team is on the fence with this. Assuming the majority of the teams competing are shooting for a weight near or equal to 120 lbs, we're more comfortable trying for a heavier bot due to the inevitable fact that if there are more heavy bots competing, a light bot would be pushed around.
We had this problem in the last competition, wherein our bot was lighter than the others, and the other heavier bots tended to push ours right out of the way.
It's a hard decision to make; sacrifice endurance for speed, or increase the weight for steadier shooting at the cost of a slower robot.
Unread 03-02-2012, 19:39
Andrew Lawrence
Re: Robot Weight
We're aiming for 120. That way since most teams are around that weight, it'll be easier to balance the bridge. Only thing now is to start drilling holes! Actually, we may come in a littl under this year. We'll then need to pack on extra stuff to get to 120!
Unread 03-02-2012, 20:21
Re: Robot Weight
We're aiming for 120 and on course for 130
Bare frame, pretty much complete with all the mounting brackets for everything, is 27 lbs.
Unread 04-02-2012, 17:47
Mr. Rogers's Avatar
Mr. Rogers Mr. Rogers is offline
That? That was in the CAD.
FRC #3539 (Byting Bulldogs)
Mr. Rogers will become famous soon enoughMr. Rogers will become famous soon enough
Re: Robot Weight
We're at 118 lbs, but a few small components still need to be added. That's too bad, now we'll have to water jet our logo out of some parts of the robot.
Grow the roses of success!
2011 Archimedes 2nd seed,
2011 Waterford Champion, 2011 Troy Simi-Finalist,
2011 Waterford Rookie all star, 2011 Troy Rookie all star
http://www.bytingbulldogs.com/
Unread 04-02-2012, 18:03
Happy Birthday! davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Re: Robot Weight
Our drive alone is 86 lb... I am worried...
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 04-02-2012, 20:02
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Re: Robot Weight
That is actually something to be worried about. Ours was ~65 last year, and we had dual layers of T-Slot and tubing, along with 8 idlers and tank treads. This year, we're down to ~50, after beginning the transition to sheet metal construction by water-jetting our side panels out of 3/16th plate. What are you guys doing that requires 86 lbs? Unless its two drive trains for going X and Y, you might want to get out the drill.
Unread 04-02-2012, 21:42
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Robot Weight
I warned everyone about it, but they went with the 14 inch wheels. In order to support those 14 inch wheels, one of our mentors had to make a brace for the sprocket. In order to chain them up, 4 big metal plates are required for the gearboxes. It is slow, sluggish and cumbersome. It was designed to to over the bump, but it flips over.
Unread 04-02-2012, 22:43
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Re: Robot Weight
I second this, our 2012 robot was 78 lbs with the drive-train, and while making weight wasn't all that hard It was very limiting to us and caused a lot of stress. I would try to cut weight wherever you can, learning from last year we managed to got our 2012 robot down to 51 Lbs without any worries about structural strength. If you need more than 30LBS for a frame, you are doing something wrong.
