Go to Post When a team is a team, anything is possible - Bharat Nain [more]
Unread 23-01-2012, 12:48
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: pic: How will 3620 use this gear?
Originally Posted by squirrel View Post
Neat, dual FPs! Are you going to add cooling air holes to the Front Plate?
Thanks! And yes, cooling holes will be needed. I am thinking 15/64" diameter, eight places on a 0.931 circle. Or something like that.
These motors do need air flow-through, or they'll cook.
Also, the detailed dimensions visible on the drawing may not be correct -- they are based on 0.8 module gear teeth -- actual tooth size is more likely 32 DP. Also, they are based on a 19 tooth pinion, and our -9013 motors have 13 tooth pinions.
Richard Wallace
since 2003
