Go to Post do the math, then use the math to go for total overkill. - pfreivald [more]
Unread 23-01-2012, 14:18
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: FRC 4532 Drive Base Frame
Originally Posted by mechanumrules View Post
I'm telling you, this drivetrain is money! We're using AM Toughboxes with an external sprocket reduction of somekind, (I don't know, I'm a software guy!) to give us a final speed of 6.2xx fps. Should be enough torque to overcome the carpet scrub, right? We don't need to be fast this year, absolute precision is key!
And I'm (we're) telling you, a ten year veteran of FRC mechanical systems, that this 4WD drivetrain might have some serious issues and that you need to test it out before you assume that it will work. We are all trying to help you out here.
The jumping, jittering, unstable turning is VERY characteristic of this sort of drive train; and, as SteveGPage said, it is NOT precise at all, but instead is nearly un-drivable.
