Go to Post No matter what route you choose, it's always a good idea to keep Mike Walker's cell phone on speed dial. - Joe Ross [more]
Unread 23-01-2012, 15:14
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: pic: How will 3620 use this gear?
Originally Posted by Richard View Post
Let see. if that is the FP and the first stage from the FP gearbox you have a 13 tooth pinion and a 72 tooth driven gear that gives a speed reduction of 72/13 = ~5.54
Based on data from the FIRSt provided motor specs (http://www.usfirst.org/sites/default...torInfo4.1.pdf) the FP -9013 has a free speed of 16700 RPM. After this reduction that works out to ~3015 RPM. Gosh Richard, what could you ever want spinning that fast?
I wonder if you put a wheel on that shaft what kind of surface speeds you could get?
Mark
Brick walls are for other people. - Randy Pausch
