Go to Post If you water it and nurture it and fertilize it and put it out in the sunlight, it might just grow up to be a big lathe... :) - dlavery [more]
Unread 23-01-2012, 15:15
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
Re: pic: FRC 4532 Drive Base Frame
Originally Posted by mechanumrules View Post
I'm telling you, this drivetrain is money! We're using AM Toughboxes with an external sprocket reduction of somekind, (I don't know, I'm a software guy!) to give us a final speed of 6.2xx fps. Should be enough torque to overcome the carpet scrub, right? We don't need to be fast this year, absolute precision is key!
Does it drive yet? If so, weight it up and turn it on carpet (and videotape it). If it doesn't, your main concern should be getting it there. It looks easy enough to switch in omnis if you decide you need them. Either way, I'd suggest you stop extolling the hypothetical performance without recording the actual one. That's plenty to do itself, good luck!
