Go to Post I like anything that is designed to bounce for up to 10 minutes. Expecially if it lands right side up :) - GregT [more]
Unread 24-01-2012, 12:40
Mr. Rogers's Avatar
Mr. Rogers Mr. Rogers is offline
That? That was in the CAD.
FRC #3539 (Byting Bulldogs)
Mr. Rogers will become famous soon enoughMr. Rogers will become famous soon enough
Re: pic: FRC 4532 Drive Base Frame
Put in 2 more 8'' pneumatic tires in the center, drop them a 1/4'', and you'll be gold (for this configuration) Otherwise you are placing about 35lbs on each wheel (assuming you build about max weight) and these wheels are very grippy on carpet. With a wheel base that long, your drivers will be very unhappy. We almost did something like that last year (our rookie year) but our mentor team helped us impliment a much better 8wd with the 2 center pair of wheels dropped about 1/8'' to 1/4'' (I would go 1/4'' using pneumatics, they squish alot more) And find time to test whatever you have on carpet before your regional!!!!
Grow the roses of success!
2011 Archimedes 2nd seed,
2011 Waterford Champion, 2011 Troy Simi-Finalist,
2011 Waterford Rookie all star, 2011 Troy Rookie all star
http://www.bytingbulldogs.com/
