Go to Post don't be grumpy. No one is allowed to be grumpy during build. - JaneYoung [more]
  #31   Spotlight this post!
Unread 10-01-2012, 17:08
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Mark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond repute
Re: paper: FRC cRIO II
I've seen that error go away when all other NICs get Disabled.
"Rationality is our distinguishing characteristic - it's what sets us apart from the beasts." - Aristotle
  #32   Spotlight this post!
Unread 10-01-2012, 22:16
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by RufflesRidge View Post
Make sure your computer's netmask is set to 255.255.255.0 and that you have disabled (by right clicking and selecting "Disable") any adapters other than the one being used to connect to the cRIO.
Originally Posted by The Trooper View Post
I have done that, and it still does that.
Are you certain? You might have a FireWire or VPN "network adapter" enabled. What does the result of the ipconfig command show you? Copy it here so we can check it for anything out of the ordinary.
You might also have a Windows firewall enabled. Shut anything like that off.
  #33   Spotlight this post!
Unread 13-01-2012, 09:55
The Trooper The Trooper is offline
FRC #2559 (nOrMaLiTy zErO)
The Trooper is an unknown quantity at this point
That worked! Thanks for the help, it works great now.
  #34   Spotlight this post!
Unread 25-01-2012, 10:46
cvessalico cvessalico is offline
FRC #0884
cvessalico is an unknown quantity at this point
When we open the 2012 Imaging tool our Laptop can't find our new cRIO FRC II. Any Suggestions?
  #35   Spotlight this post!
Unread 25-01-2012, 17:16
FRC #0884
Nevermind, we figured it out it was the laptop firewalls!
