Go to Post Being a mentor doesn't have an age requirement. As long as you are positively influencing someone you could be called a mentor and a role model. - EricLeifermann [more]
Unread 20-01-2012, 18:43
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
Re: pic: Fisher Price gearbox
Wood is good.
TheR/C car world has a lot of 32p and .8mod gears available too.
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 20-01-2012, 21:14
MrForbes MrForbes is offline
old white, new orange. Different tooth count, too
Unread 20-01-2012, 22:33
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
I count 72 teeth on the orange driven gear (and 25 on its inner driver). Can anyone confirm?
Looks like the octagon hole could be drilled out to 3/8" and then broached hex fairly easily. A three jaw should locate center well enough, if my 72 count is correct.
Richard Wallace
since 2003
Unread 24-01-2012, 23:20
We have a several of the old white first stage gears, so we decided to make a new gearbox for the 2012 robot. It is integrated with the shooter, the lexan panel it is mounted to will be the side panel of the shooter. We do need to make a new shaft, since the one shown here was fabricated in a prior year. The lexan plate that holds the motor and the hidden bearing was made tonight by students, using a 7/8" Forstner drill bit, and a small drill press. We just measured the gear spacing using a vernier caliper, laid it out carefully and drilled it. The motor is not really at tight fit in the hole, but it's good enough. If you have a way to ream or bore the hole to the proper size, that would be better. Note that this is the 2011 motor with it's 19 tooth pinion gear, not the 2012 motor.
The shooter wheel will be mounted on AM hubs, keyed to a 1/2" shaft, which will be bored to fit over the new transmission output shaft. We will probably use a roll pin or two to hold the shafts together.
Unread 25-01-2012, 13:40
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Very nice design! I will say my design is kinda parallelling this, but with 2 FP's and it's build into a piece of 1.25" C-channel. How did you pin the gear to the axle? just a roll pin?
Also, we had a 3/8" axle but found that if we tried to bore out a 1/2" shaft to fit around it to direct-drive it, we'd have a 1/16" wall around the circumference, which is relatively weak. Instead we bored out a 5/8" shaft and drilled out the center of our AM hubs to attach it to the throwing wheel. If you're worried about the strength of the 1/2" shaft, try that.
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 25-01-2012, 13:43
The shaft is 3/8" hex, with the ends turned to fit into the 3/8" ID bearings. The older FP first stage gear happens to have a 3/8" hex hole in it.
I was thinking we might step it down to 5/16" where it enters the 1/2" shaft, or possibly make a larger diameter coupler to fit over both shafts (for example, by turning the end of the 1/2" shaft to 3/8", and using a short length of 1/2" od 3/8" id steel tube)
Unread 25-01-2012, 13:50
Tom I's Avatar
AKA: Tom Indelicato
Yeah I was fearing that... We were trying to avoid getting the hex shaft. We have the capabilities to do so, we just didn't want to make that investment... I'm thinking we'll give pinning it a try, and if that fails we'll have a hex shaft ready to go.
Okay, glad to see you guys are thinking about connecting the two the right way. Let me know how it all comes together! (It's kinda scary how our two designs are similar... our turrets are basically the same as well)
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 25-01-2012, 14:25
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
I suspect this is one of those cases of design convergence around a common goal. We are doing something similar, except using a steel center gear with a 3/8" bore keyed to a 3/8" dia wheel shaft. I don't trust that a plastic gear will hold up to the shock loading the gear mesh will see when the balls are fed into the shooter.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 25-01-2012, 15:10
Tom I's Avatar
AKA: Tom Indelicato
We've done it before in Lunacy. The plastic gear seemed to do pretty well, and this was the year we named our robot the "Noisy Cricket" because the wheel was spinning so fast... yeah. But as long as the gears are mounted properly and the teeth mesh well, you shouldn't have a problem. Metal gears will also do you well but again be sure the gears mesh well.
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 25-01-2012, 15:39
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
On the bright side, Andy Mark now makes the CIM-Sim. We've got one year and with two motors on it she screams like a banshee.
http://www.andymark.com/product-p/am-0932.htm
Unread 25-01-2012, 16:03
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
If only you could actually buy one.
I've come to the conclusion that the only way to get a robot done ahead of time is to drop tons of cash on transmission components before the season starts, and hope they are legal.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 25-01-2012, 16:05
Matt C's Avatar
FRC #1468 (J-Birds)
I guess we got lucky, we purchased ours last week.
Fisher Price Gearbox nreynolds General Forum 23 22-01-2008 13:18
Fisher-Price Gearbox? Aaron Motors 4 17-02-2004 17:41
Fisher Price gearbox Manoel Motors 0 14-02-2003 16:06
Fisher Price Gearbox Q... Anton Abaya Motors 17 27-01-2002 08:39
