Go to Post You can admire machines, but you don't really love them... This program has enabled me to make a difference that I believe is good for the future of humans on this planet. - MooreteP [more]
Unread 28-01-2012, 20:13
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: pic: Polycord Welding
Originally Posted by codes02 View Post
Any reason you guys are melting the polycord together instead of just tieing it?
My team has decided to go with tieing due to concerns about the melted together joint being weak and our inability to identify any benefit to melting it
Teams are melting it because that is the proper method for joining/welding it.
Welded joint is as strong as the cord itself. We pull test every joint, and have never had a failure in competition.
If your team does not want to join it with heat, I suggest using the hollow polycord with connectors or find another belt system to use.
