Go to Post Seems decretive bumpers are the new rage now. I couldn't stand making them once, never mind twice. - Gregor [more]
Unread 28-01-2012, 21:34
V_Chip's Avatar
V_Chip V_Chip is offline
Back in action.
AKA: Victor
FRC #0175 (Buzz Robotics)
V_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud of
Re: pic: Polycord Welding
For out polycord welding we milled out a simple assembly like above.
Two 1" blocks of aluminum are attached to a rail system on a base. The tops are notched to cradle the polycord.
On one of the sliders there is a hole just large enough to put the polycord through. Each end of the cord is slid through and cut against the face of aluminum with a razor blade so that it's perfectly flat.
The hot knife is then held between the seated ends. Once hot the rail cradles are slid together and form a clean and even "weld"!
I can upload some photos upon request.
