Go to Post An FRC team's success should not be measured in how many robots it can build or how many blue banners it can collect. It should be measured by how many engineers (and other professionals) it 'builds'. - jvriezen [more]
Unread 30-01-2012, 22:47
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Re: pic: Team 1296 teaser!!!
Originally Posted by BlacksmithWoods View Post
Cool, looks like your CIM motor limit is almost used up. What motors are you planning on using to pick the balls up and fire your launcher, if you are using a launcher. Also, how are you going to avoid the penalty of herding more than 3 balls at once. Once it is inside your frame it is considered to be "herded".
We are using AndyMark and FP motors on the launcher wheel. The conveyors will run backwards to reject balls as well as pull them in.
