Go to Post ...Al Skierk, uh, Skierwike, uh, you know who I mean - Gary Dillard [more]
Unread 02-01-2012, 10:17 AM
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Taking some personal time
EricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond repute
Re: pic: Wave Robotics 2826 Drive Teaser
With that low of a ground clearance I take it you're not going over the barrier this year?
2002-2005 Appleton East High School: Team 93
2005-2011 Michigan Technological University: Team 857
2012-2016 Wave Robotics Team 2826
Unread 02-01-2012, 10:18 AM
EricH EricH is offline
I think they are. That's a Delrin angle on the near end, or I'm greatly mistaken.
Unread 02-01-2012, 10:22 AM
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
What size are the wheels? I don't really have a good perspective to tell if they are 4" or 6".
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 02-01-2012, 10:23 AM
Andrew Lawrence
Excuse my curiosity, but what's a Delrin Angle? I'm assuming it's the slanted piece to go over the bump, but then again, you never know. Well, you probably know, but I don't.
Thanks!
Unread 02-01-2012, 10:25 AM
Thanks!
The angled part of the frame appears to be covered by Delrin, which is a rather slick type of plastic. The other option that I can think of, HDPE, is also somewhat slick, but Delrin is slicker. In block form, Delrin has been used as a chain tensioner in the past--stick the block in so the chain is slightly too tight and let it find its own tension by digging into the block.
Unread 02-01-2012, 10:28 AM
Andrew Lawrence
Thanks! I appreciate it!
Thanks!
Delrin is a material developed by DuPont and is widely used by teams. That piece could also be HDPE or UHMW.
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
The sheetmetal parts are looking great this year guys. Looking forward to seeing the completed robot. I'm interested to see exactly how you are powering the wheels as it appears to be dead axles (3/8" Grade 8 Bolts) but I don't see any pulleys or sprockets.
Looks like about an 1" of ground clearance. And I believe those slides on the front edge of the chassis (im guessing teflon, Delrin, or HDPE) allow them to go over the barrier, FRC2168 is doing something similar this year.
Unread 02-01-2012, 10:34 AM
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
If you zoom into the picture, it looks as if the wheels are riding on hex shafts, if so, I'd imagine that the ends of the shafts have been drilled and tapped to allow the use of bolts as retainers.
-Dustin Benedict
Unread 02-01-2012, 02:00 PM
Excellence is Bliss
FRC #0111 (WildStang)
That sheet metal work is absolutely gorgeous. Looking great so far! How high will your bumpers be?
Unread 02-01-2012, 02:07 PM
FYI
Delrin is the Dupont trade name for Acetal.
Thank-you 294 & 67
Unread 02-01-2012, 02:45 PM
waialua359's Avatar
waialua359 waialua359 is offline
AKA: Glenn
FRC #0359 (Hawaiian Kids)
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
That robot is definitely going over the bump.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Unread 02-01-2012, 03:56 PM
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
I only have one question what is the angle of the thing in the front?
Unread 02-01-2012, 06:16 PM
mr.roboto2826's Avatar
mr.roboto2826 mr.roboto2826 is offline
AKA: Niklas Olsen
mr.roboto2826 is just really nicemr.roboto2826 is just really nicemr.roboto2826 is just really nicemr.roboto2826 is just really nicemr.roboto2826 is just really nice
We are powering the wheels Via belt and pulley, similar to a west coast in some respects. It runs inside of the 2 C channels that make up one side of our drivetrain. The wheels are our custom 4".
Unread 02-02-2012, 09:12 AM
Mr. Rogers's Avatar
Mr. Rogers Mr. Rogers is offline
That? That was in the CAD.
FRC #3539 (Byting Bulldogs)
Mr. Rogers will become famous soon enoughMr. Rogers will become famous soon enough
Those are nice looking wheels, where did you get that black tread??
Grow the roses of success!
2011 Archimedes 2nd seed,
2011 Waterford Champion, 2011 Troy Simi-Finalist,
2011 Waterford Rookie all star, 2011 Troy Rookie all star
http://www.bytingbulldogs.com/
