Go to Post Put on shows. Start new teams, FRC, FVC, or FLL. It doesn't matter. But I know that being on the robotics team has given me some of the best memories of my life, and I wouldn't want anybody else to miss out on that. - irishninja [more]
Unread 01-02-2012, 10:16
MrForbes MrForbes is offline
pic: What is 1726 up to now?
Unread 01-02-2012, 10:18
Andrew Lawrence
Re: pic: What is 1726 up to now?
So what's that thing in the front? Why is it only letting one ball in at a time? Why does your ball intake only go so far? What's that thing in the back (probably an electronics board, but who knows?)?
Unread 01-02-2012, 10:19
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
4130 steel again this year?
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 01-02-2012, 10:25
It's mild steel, nothing fancy. We have a freshman on the team this year who has done a little bit of MIG welding, so he's building the chassis. The wood is indeed part of the electronics box, but the rest of it will be quite a bit bigger.
Unread 01-02-2012, 12:45
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
That looks like it is there to satisfy the bumper rules. It looks like you can easily get two balls in there and then it funnels it down to one ball immediately. We used a similar style in 2009 and it works very well.
1058 PVC Pirates 2016 - xxxx
Unread 01-02-2012, 12:50
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
What's the wall thickness on your steel? Always thought thinner wall steel tubing (less than .060" or so) would be neat to play with in FRC.
-Dustin Benedict
Unread 01-02-2012, 15:05
The square tubing is thinwall like 16 ga. Not real thin, but not very heavy either ( slightly heavier than 1/8" aluminum)
There is room for two balls to get stuck in the pickup, when that happens we'll run it in reverse to spit them out. The plan is to only pick up one at a time.
Unread 02-02-2012, 19:50
ChristopherSD's Avatar
ChristopherSD ChristopherSD is offline
FRC #0201 (FEDS 201)
ChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud of
Bump or bridge?
Unread 02-02-2012, 22:54
As of tonight, we should be able to do both. We added a bunch more parts...it's getting heavy...which is what you expect when you build from steel, right?
Unread 02-02-2012, 23:17
chadr03's Avatar
chadr03 chadr03 is offline
FRC #2582 (PantherBots)
chadr03 has a spectacular aura aboutchadr03 has a spectacular aura aboutchadr03 has a spectacular aura about
Looks good. Does the wooden box articulate? How much does it weigh? We are just gonna squeak under the 120# this year. Already at 106# and a few more things to add.
Unread 02-02-2012, 23:24
I don't know how heavy it is now....but it's getting up there. Fortunately the stuff on top will be relatively light. The electronics box just sits there and holds electronics.
Unread 03-02-2012, 23:42
The team decided to paint the frame sliver. It weighs 27 lbs as pictured.
Unread 03-02-2012, 23:44
Andrew Lawrence
Looks great! Now let's see the finished version!
Unread 03-02-2012, 23:45
This is the finished version of the frame, we're hoping to have the whole thing put together soon...but I'll be surprised if it's done by the end of next week. Wait...what week is this?
Unread 09-02-2012, 19:43
We're making progress....should be done by the 21st, hopefully!
