Go to Post FIRST is supposed to prepare you for a focused career in your subject of interst, and help you manage your time and resources effectively. - Eugenia Gabrielov [more]
Unread 01-02-2012, 22:56
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: pic: Gasp!
Originally Posted by akoscielski3 View Post
I'm debating whether your "gasping" about the jaguar used for the motor, or that zip ties are connecting them to the electrical board? Is zip ties legal to use as the connectors for the controller??
Zip ties are what make the FIRST world go round…
Normally, for a competition bot, we use 6-32 screws to mount our electronics, but right now on our proto-bot, hundreds of dollars of equipment are mounted with zip ties. It actually saved us once this year: We hit the barrier a little too hard, and the particle board we had everything mounted on broke right under the PD board. If that had been bolted down, it would have most likely cracked the mounting holes on it.
I'm right 90% of the time, so why worry about the other 3%?
