Go to Post Darn, I won't be at Pittsburgh. But I ain't going anywhere this year without my gracious professionalism! - Eugenia Gabrielov [more]
Unread 02-02-2012, 23:43
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: pic: Gasp!
Originally Posted by gpetilli View Post
We are doing the same thing. The 393 data sheet calls it a 7.2V motor with 8.5V max so you are correct to be worried about applying 12V. Assuming you use CAN bus, the Jaguar allows you to set a VMax for lower voltage motors. I dont think i would try this using only PWM input to the Jaguar.
No matter what you set the VMax to, the motor will still see full voltage (between 13 and 7 volts depending on state of charge and current draw). VMax pulses the motor to limit the AVERAGE voltage. The maximum voltage actually supplied doesn't change.
