Go to Post There's a fine line between insanity and healthy obsesion with FIRST ... and sometimes I wonder which one I'm on - srawls [more]
Unread 07-02-2012, 23:43
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: paper: LabVIEW Mecanum Programming
If you want to put a constant in the global variable, you need to write to it. You would read it if you want to do something with the value it contains.
