Go to Post The sign applause was definately one of the best moments I had ever witnessed at a FIRST event. Who knew silence could be so loud? - Koko Ed [more]
Unread 09-02-2012, 00:08
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
Re: pic: Team 192 teaser
The gear box was project of some of the students. They did the research and design by themselves. It looks better in person then in the picture.
For over a decade 192 has used 12 volt battery drills as power sources. This gives you a variable voltage reversible polarity hand held power source. We use Anderson power pole connectors on all of our motors. This allows us to run any motor without powering the whole robot or to run tests of components on the work bench. Two will run the four motor drive train for a short bit. It is best if you put at least a one foot lead for the connectors. The drill motors make great motors for design projects during the fall.
