Go to Post You mean how many Edible Data Analysis Metrics and Aggregated Measurable Entities (EDAMAME)? - Andrew Schreiber [more]
Unread 09-02-2012, 13:12
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Re: pic: Wheel
Originally Posted by DampRobot View Post
Wow, that's an amazing machining job! Did you machine it yourself just to get the diameter to 3.5 inches? I really like how you integrated the sprocket with the wheel.
I started with a 3.75" OD stock and Machined the sprockets as well as removed a lot of material from the other side.
Unread 09-02-2012, 13:24
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: pic: Wheel
Why?
What advantages does this offer over a more common, more flexible approach?
--Madison--
...down at the Ozdust!
Unread 09-02-2012, 13:27
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: Wheel
Why?
I will have to echo this question.
That said it is definitely "cool"
Mentor 2415
Unread 09-02-2012, 13:30
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Re: pic: Wheel
Why?
I find it cool that the sprocket is part of the wheel... this allows for a rigid "mount" that cannot be beat.
Unread 09-02-2012, 13:33
AKA: Sean
Re: pic: Wheel
Originally Posted by Sean Raia View Post
I find it cool that the sprocket is part of the wheel... this allows for a rigid mount that cannot be beat.
It's definitely rigid at the expense of a huge amount of machining time and material waste. The sprocket also doesnt have the typical chamfer which could lead to interesting performance as well.
Mentor 2415
Unread 09-02-2012, 14:43
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: pic: Wheel
Yeah, I'd be interested in how the sprocket without the chamfer would work out. I predict finikeyness if not executed properly...
Unread 09-02-2012, 13:34
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: pic: Wheel
Why?
Someone has an extreme aversion to fasteners?
In a way, it's built like an aircraft part: lots of material wasted to get a complex solid shape—but few fasteners and joints to worry about, and minimal weight. But it seems like if you're going to go to those lengths to save weight, you ought to do something about the rim thickness. (Or is it going to be sliced much narrower later, and/or turned down significantly?)
Unread 09-02-2012, 14:11
Jeff 801's Avatar
Re: pic: Wheel
Why?
It removes 6 bolts, nuts, washers and spacers per wheel from your drive system.
Machine time is really not that bad because all that really is added is a roughing operation to remove the material from the OD of the wheel to the OD of the sprocket then an 1/8" cutter does the teeth of the sprockets and for extra lightning I went in with a 3/16 cutter to put the spokes on the sprockets then finished it a woodruff/ keyseat cutter to get the space between the sprockets.
As far as material waste it uses an extra 3/4" of stock on the wheel.
The lack of the chamfer is not that big of a deal I have ran sprockets like this over the past 3 seasons with no issues.
Unread 09-02-2012, 15:47
JamesBrown JamesBrown is offline
Back after 4 years off
FRC #5279
JamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond repute
Re: pic: Wheel
What is the weight benefit for that? Is there another benefit besides weight? This just seems like a really impractical way to make a wheel.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 10-02-2012, 10:39
Kevin_Morris's Avatar
Kevin_Morris Kevin_Morris is offline
Kevin_Morris has a brilliant futureKevin_Morris has a brilliant futureKevin_Morris has a brilliant futureKevin_Morris has a brilliant futureKevin_Morris has a brilliant futureKevin_Morris has a brilliant futureKevin_Morris has a brilliant futureKevin_Morris has a brilliant futureKevin_Morris has a brilliant futureKevin_Morris has a brilliant futureKevin_Morris has a brilliant future
Send a message via AIM to Kevin_Morris
Thumbs up Re: pic: Wheel
Not to give the textbook mentor answer, but if students learned in the process, I see that it has more benefit than just weight saving. If they didn't... well it's still pretty nifty.
I too was wondering why the rim thickness was kept so thick, until I realized the center spokes of the wheel are only about 3/4" or so wide (relative to wheel width). I also realized that's what you meant by "a lot of material was removed from the back side".
Unread 10-02-2012, 11:11
electron's Avatar
electron electron is offline
Former Team Overdrive member
AKA: Joseph
FTC #2753 (Team Overdrive)
electron is just really niceelectron is just really niceelectron is just really niceelectron is just really nice
Re: pic: Wheel
Despite the obvious comments of "why?" and "where is the chamfer?", I must say that this looks like a very fun CAD and machine job! I give you many props for pulling it off!
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
I may be one of the few people that has moved from FRC to FTC, and enjoyed it
Unread 10-02-2012, 13:47
FRC #5279
Re: pic: Wheel
I agree to an extent that projects for the sake of learning are great but one of the biggest lessons to teach students is how to compare solutions (time, complexity, cost, weight, etc) to choose the appropriate one.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 11-02-2012, 04:39
Jeff 801's Avatar
Re: pic: Wheel
The outside of the wheel is really not that thick if you look at this picture you will get a better idea of why you thought it was. The spokes are only 1/4" wide. When I said remove material on the back side it was to take the OD of the part from 3.75 to the OD of the sprockets at ~2.15"
I understand cost benefit analysis. The addition of the double sprocket added only 30 min to the total cycle time of the wheel. In that added 30 min a total of 26 individual components were removed from each wheel (assuming the use of individual spacers). In the end its a simple and elegant solution to making a wheel and sprocket assembly simpler.
Unread 09-02-2012, 14:13
45Auto's Avatar
45Auto 45Auto is offline
FRC #2992
45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future
Re: pic: Wheel
Just think how much fun it'll be when you find out you need a slightly larger or smaller sprocket!
2007 - Rookie All Star - Bayou Regional (1858 - Tyborgs)
2009 - Rookie All Star - Bayou Regional (2992 -Prometheus)
2010 - Champions - Bayou Regional (2992 -Prometheus)
2012 - Finalist - Bayou Regional (2992 - Prometheus)
team2992.com/design.php
Unread 09-02-2012, 14:17
Jeff 801's Avatar
Re: pic: Wheel
On the drive system between wheels the ratio should always be 1:1 (assuming same wheel size) and with one of the wheels being direct drive if there is a ratio issue it would be accounted for in the gearbox
