Re: pic: Wheel
Why?
What advantages does this offer over a more common, more flexible approach? |
Re: pic: Wheel
That said it is definitely "cool" |
Re: pic: Wheel
I find it cool that the sprocket is part of the wheel... this allows for a rigid "mount" that cannot be beat.
Re: pic: Wheel
It's definitely rigid at the expense of a huge amount of machining time and material waste. The sprocket also doesnt have the typical chamfer which could lead to interesting performance as well.
Re: pic: Wheel
Yeah, I'd be interested in how the sprocket without the chamfer would work out. I predict finikeyness if not executed properly...
Re: pic: Wheel
In a way, it's built like an aircraft part: lots of material wasted to get a complex solid shape—but few fasteners and joints to worry about, and minimal weight. But it seems like if you're going to go to those lengths to save weight, you ought to do something about the rim thickness. (Or is it going to be sliced much narrower later, and/or turned down significantly?) |
Re: pic: Wheel
As far as material waste it uses an extra 3/4" of stock on the wheel. The lack of the chamfer is not that big of a deal I have ran sprockets like this over the past 3 seasons with no issues. |
Re: pic: Wheel
What is the weight benefit for that? Is there another benefit besides weight? This just seems like a really impractical way to make a wheel.
Not to give the textbook mentor answer, but if students learned in the process, I see that it has more benefit than just weight saving. If they didn't... well it's still pretty nifty.
I too was wondering why the rim thickness was kept so thick, until I realized the center spokes of the wheel are only about 3/4" or so wide (relative to wheel width). I also realized that's what you meant by "a lot of material was removed from the back side". |
#10
Re: pic: Wheel
Despite the obvious comments of "why?" and "where is the chamfer?", I must say that this looks like a very fun CAD and machine job! I give you many props for pulling it off!
#11
Re: pic: Wheel
I agree to an extent that projects for the sake of learning are great but one of the biggest lessons to teach students is how to compare solutions (time, complexity, cost, weight, etc) to choose the appropriate one.
#12
Re: pic: Wheel
![]() I understand cost benefit analysis. The addition of the double sprocket added only 30 min to the total cycle time of the wheel. In that added 30 min a total of 26 individual components were removed from each wheel (assuming the use of individual spacers). In the end its a simple and elegant solution to making a wheel and sprocket assembly simpler. |
#13
Re: pic: Wheel
Just think how much fun it'll be when you find out you need a slightly larger or smaller sprocket!
#14
Re: pic: Wheel
On the drive system between wheels the ratio should always be 1:1 (assuming same wheel size) and with one of the wheels being direct drive if there is a ratio issue it would be accounted for in the gearbox
