Go to Post Don't date anyone on your team unless you are POSITVE that you will be able to handle yourself professionally, not only during your relationship, but even after it ends. - Jaine Perotti [more]
Unread 09-02-2012, 14:11
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Re: pic: Wheel
Why?
What advantages does this offer over a more common, more flexible approach?
It removes 6 bolts, nuts, washers and spacers per wheel from your drive system.
Originally Posted by sdcantrell56 View Post
It's definitely rigid at the expense of a huge amount of machining time and material waste. The sprocket also doesnt have the typical chamfer which could lead to interesting performance as well.
Machine time is really not that bad because all that really is added is a roughing operation to remove the material from the OD of the wheel to the OD of the sprocket then an 1/8" cutter does the teeth of the sprockets and for extra lightning I went in with a 3/16 cutter to put the spokes on the sprockets then finished it a woodruff/ keyseat cutter to get the space between the sprockets.
As far as material waste it uses an extra 3/4" of stock on the wheel.
The lack of the chamfer is not that big of a deal I have ran sprockets like this over the past 3 seasons with no issues.
Unread 09-02-2012, 15:47
JamesBrown JamesBrown is offline
Back after 4 years off
FRC #5279
JamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond repute
Re: pic: Wheel
What is the weight benefit for that? Is there another benefit besides weight? This just seems like a really impractical way to make a wheel.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 10-02-2012, 10:39
Kevin_Morris's Avatar
Kevin_Morris Kevin_Morris is offline
Kevin_Morris has a brilliant futureKevin_Morris has a brilliant futureKevin_Morris has a brilliant futureKevin_Morris has a brilliant futureKevin_Morris has a brilliant futureKevin_Morris has a brilliant futureKevin_Morris has a brilliant futureKevin_Morris has a brilliant futureKevin_Morris has a brilliant futureKevin_Morris has a brilliant futureKevin_Morris has a brilliant future
Send a message via AIM to Kevin_Morris
Thumbs up Re: pic: Wheel
Not to give the textbook mentor answer, but if students learned in the process, I see that it has more benefit than just weight saving. If they didn't... well it's still pretty nifty.
I too was wondering why the rim thickness was kept so thick, until I realized the center spokes of the wheel are only about 3/4" or so wide (relative to wheel width). I also realized that's what you meant by "a lot of material was removed from the back side".
Unread 10-02-2012, 11:11
electron's Avatar
electron electron is offline
Former Team Overdrive member
AKA: Joseph
FTC #2753 (Team Overdrive)
electron is just really niceelectron is just really niceelectron is just really niceelectron is just really nice
Re: pic: Wheel
Despite the obvious comments of "why?" and "where is the chamfer?", I must say that this looks like a very fun CAD and machine job! I give you many props for pulling it off!
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
I may be one of the few people that has moved from FRC to FTC, and enjoyed it
Unread 10-02-2012, 13:47
FRC #5279
Re: pic: Wheel
I agree to an extent that projects for the sake of learning are great but one of the biggest lessons to teach students is how to compare solutions (time, complexity, cost, weight, etc) to choose the appropriate one.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 11-02-2012, 04:39
Jeff 801's Avatar
Re: pic: Wheel
The outside of the wheel is really not that thick if you look at this picture you will get a better idea of why you thought it was. The spokes are only 1/4" wide. When I said remove material on the back side it was to take the OD of the part from 3.75 to the OD of the sprockets at ~2.15"
I understand cost benefit analysis. The addition of the double sprocket added only 30 min to the total cycle time of the wheel. In that added 30 min a total of 26 individual components were removed from each wheel (assuming the use of individual spacers). In the end its a simple and elegant solution to making a wheel and sprocket assembly simpler.
