Go to Post I, for one, am perfect and therefore make no mistakes. (Unless you count all the times that I completely screw up) - Molten [more]
Unread 10-02-2012, 09:14
FRC #2220
Re: pic: Team 1683 TechnoTitans Base and Ball Collector
Originally Posted by Whateveryousay View Post
as i said, center dropped 6 wheels, at any time, we only have 4 wheels on the ground, and we can do 360 even on the carpet, i dont think i will consider that immovable
What is the drop of the center wheel? As a note of caution, our team used a similar setup with 6 pneumatic wheels and a 1/4" drop in the center wheel. We were able to pivot on a dime while testing, but once we added all the weight of other components, we found the compression in center wheel eliminated the drop and made turning almost impossible. (The lateral coefficient of friction on those wheels seems to be rather high) Have you gotten around this problem?
