Go to Post "Oh, the farmer and the cowhand can be friends, la la la..." - Andy Baker [more]
Unread 13-02-2012, 17:24
ChristopherSD's Avatar
ChristopherSD ChristopherSD is offline
FRC #0201 (FEDS 201)
ChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud of
Re: pic: Team 714 week 3 robot
Will the front bumpers be at least 8" long?
R27 Bumper Rule
Unread 13-02-2012, 19:19
bhumudar's Avatar
bhumudar bhumudar is offline
Mentor/Programming/Electrical
AKA: Bryant Humud-Arboleda
FRC #0714 (Panthera)
bhumudar is on a distinguished road
R27 Bumper Rule
Yes the bumpers will be 8 inches long on both sides of the gap on the back side of the robot. Granted we will lose some space to pick up the balls though.
Unread 13-02-2012, 19:43
msulaimain's Avatar
msulaimain msulaimain is offline
AKA: Muhammad Sulaiman
FRC #3346 ([{Kamikaze Komets}])
msulaimain can only hope to improve
Send a message via AIM to msulaimain Send a message via Yahoo to msulaimain
Nice chassis. Nicely machined.
int main()
::::::::: include=>commitment;
::::::::: int=>school name=>Asheboro::High
::::::::: int=>team name=>Kamikaze::Komets;
::::::::: Priority_Queue=>FRC Championship::2012;
::::::::: Max_Element=>Teamwork;
Unread 13-02-2012, 20:16
run the trap!!!
Team Role: Human Player
Very interesting looking design. I suppose you are planning to shoot all three balls at once?
And what's going on with your middle wheels? Is that a suspension system for crossing the bump?
-Philip J. Fry
Unread 13-02-2012, 21:47
bhumudar's Avatar
Well all three balls do fit in the cannon, but we can only effectively shoot two at a time if needed. The robot will only be shooting one ball at a time for the most part though.
As far as the middle wheels go, what you there is a pneumatic system which drops the wheels allowing the robot to move only on four wheels, thus allowing for tighter turns and increased maneuverability. It also raises them allowing all six wheels to be on the ground which increases our traction.
Unread 14-02-2012, 09:22
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Have you guys had any problems with your frame twisting due to the large opening in the front? The reason I ask is that we have, although we have more cross bracing than you. We had issues with all wheels not touching the ground until we were able to loosen up many bolts, clamp down the robot on a table and tighten up everything and then it was okay.
Unread 14-02-2012, 10:34
bhumudar's Avatar
Well to answer your question, at this point, yes the frame did twist. Although we have added more mechanisms and structural supports. I'm just waiting for another more recent picture that I posted to be approved so that you can see more clearly. Also, what material are you using for your frame and cross bracing?
Unread 14-02-2012, 11:21
DavidGitz's Avatar
Our lower frame is made out of the KitBot material with most of the frame above made out of 8020. One of the benefits (and drawbacks) with 8020 is that you can fairly easily slide pieces around for adjustability. To deal with the twisting issue not only do we have cross braces in the front but at critical points we had to drill through and bolt components together. This is something we learned about 8020 many moons ago so we know how to deal with this now. Here is a link to some pictures of them.
