Go to Post Remember that it's not what is on the outside of the shirt that matters, it's what is on the inside. - dtengineering [more]
Unread 14-02-2012, 01:05
aeniug2's Avatar
aeniug2 aeniug2 is offline
AKA: Joseph
FRC #2879 ("Orange Thunder")
aeniug2 will become famous soon enoughaeniug2 will become famous soon enough
Re: pic: Team 2220 Rebound Rumble Robot (week 5)
I would love more information on it, thanks for offering.
Specifically, where to buy these fabled "connectors"...
Unread 14-02-2012, 18:15
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
I might ask one of our mentors to elaborate on this as well, but here is a link to the 80/20 webpage on different fasteners http://www.8020.net/Training-2.asp. I'm not entirely sure which we used.
Unread 15-02-2012, 00:27
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
80/20 is nice for a lot of things, especially quick adjustments and sliding. Their slides are a little heavy, but you can make your own, too. It's heavy, though, and it can be difficult to keep things in place under shear load.
As for the connectors, you can look up distributors on 80/20, Inc, but we get most of our stuff through Grainger and MSC.
Short overview:
Most FRC applications I've seen and used employ 10xx profiles (1"), mostly 1010 with some 1020 (1012 is cool, too). For these and other profiles, 80/20 makes fasteners that slide into the T-slot slots or can be tapped into the center axis holes. Economy nuts are probably the most common and are used in tandem with other connectors. They're slide-able when loose and can be pretty fixed when the bolt is tightened. (You can indent it a little for the bolt tip so it doesn't move.) We also use corner brackets and gussets, end caps, anchor fasteners and the occasional joining plate, most of which have various versions (multiple holes, shapes, etc). Their rollers are also really nice, though you may want to mill your own brackets for them.
Unread 15-02-2012, 00:31
aeniug2's Avatar
AKA: Joseph
Wow. Thanks for all the help... Maybe we can even find a way to use some before build is over (unlikely though, as we have no connectors and shipping would take too long).
Sorry for taking the thread a bit off topic.
I'm sure we'll be using it either in some other projects or on next year's bot (probably both).
Unread 15-02-2012, 00:41
Siri's Avatar
Dare greatly
No problem. Up to you of course, but it looks like you've got a supplier right by you. Air Engineering & Supply? Might want to check if you do need something.
Sorry, 2220. Great looking robot! My electronics guys will be even more upset with me when they see this...
