Go to Post One last thing, if a mechanical part fails on you, sometimes you can get a little bit of noise back into it by yelling at it, kicking it, or pounding on it with your fist. This might put enough back into it so it will work for a few more minutes. - KenWittlief [more]
Unread 18-02-2012, 19:02
Mike Starke Mike Starke is offline
FRCTop25.com
Mike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond repute
Re: pic: Screaming Chickens 3997 2012 Robot
Originally Posted by midway78224 View Post
Actually we did this design in solidworks and with the battery and electronics and all it should weigh about 100 lbs.
Keep in mind that the battery DOES NOT count towards your 120 lbs!
Also, I like the feature/option for human loading, and how it drops down into your harvester/collector area.
