Go to Post it takes a village to raise a robot. - Taylor [more]
Unread 19-02-2012, 18:44
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
Re: pic: Team 61 robot 2012
What kind of motor are you using on your extending arm on the front?
Van door motor
My only question is why they only focused on the 1 point shots and not the 2 point hoops? It seems that with just a tweak of their "aim" they could easily score 2 pointers.
We figure by scoring 2 balls in auto mode 100% of the time is better than trying to score at the higher hoops with less %. and then feed a great 3 point shooter.
Our robot bridge arm can lift, lower, and level if we put our wheel under the bridge. We can get on the bridge and lift it up while on it with another robot
yes we keep it simple so it will be easly to fix if broken.
Building FIRST robots since 1995
BVT Robotics
