Go to Post Remember those two words people. Gracious Professionalism. - Elgin Clock [more]
Unread 22-02-2012, 11:00
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
lynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond repute
Send a message via AIM to lynca
Re: pic: Team 341 presents Miss Daisy XI
Originally Posted by Jared341 View Post
SOFTWARE
* Completely automatic targeting via laptop-based DaisyCV image processing application
* Target detection code can run at more than 200 frames per second; it has no problems performing real-time tracking of the target regardless of lighting or even partial occlusion (such as from the rim/net)
This frame rate is very impressive.
1. What camera are you using ?
2. What are the specs of your laptop ?
3. How do you transfer information between a laptop and cRio?
4. Do you have a openCV backboard tracking example available?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 22-02-2012, 11:57
Jared Russell's Avatar
Taking a year (mostly) off
1. The Axis M1011 camera. This does limit us to 30 frames per second when operating on the robot (at 640x480 resolution), but the code itself has been shown to process upwards of 200 frames per second when streaming images from disk. In actuality, 30 frames per second is more than enough since we are actually using the gyro for doing our feedback control anyhow. At 30FPS we utilize about 15% of our CPU.
2. It's a Core i5 with 6GB of RAM.
3. Camera data goes robot -> laptop through the wireless link to the Driver Station. Computed outputs go back through the link to the cRIO using WPI Network Tables.
4. I'll post our full code after the competition season has begun. For achieving basic throughput between camera, laptop, and cRIO, you can use the example square tracker that comes with the SmartDashboard installer. Here is our basic algorithm:
1. Convert image to HSV color space
2. Perform thresholding in HSV (enforce minimum and maximum hue, minimum saturation, minimum value)
3. Find contours
4. Take convex hull of contours (this is the step that helps ensure that partial obscuration from the rim/basket doesn't kill us)
5. Perform polygon fitting to contours
6. Filter polygons based on (a) number of vertices, (b) aspect ratio, (c) angles of horizontal and vertical lines.
7. Select highest remaining polygon as the top target.
8. Compute angle from camera center to target center and add this to the current robot heading
9. Command the new heading to the robot (it uses gyro and encoders to achieve this heading)
10. Compute range based on trigonometry comparing center of camera axis to center of target height
11. Command shooter RPM setpoint based on linear interpolation of a lookup table
The code has been very carefully optimized to reduce the allocation/deallocation of dynamic memory between subsequent calls, which is what lets us operate at breakneck speed. This also involved a lot of debugging to hunt down latent memory leaks existing somewhere in the layering of OpenCV/JavaCV/WPIJavaCV APIs.
Unread 22-02-2012, 12:26
JamesTerm's Avatar
JamesTerm JamesTerm is offline
Terminator
AKA: James Killian
FRC #3481 (Bronc Botz)
JamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to behold
How did you solve the potential networking issues and latency? Do you have some interpolation for delayed frames? Do you have timestamps on the frames to know how long they took to trasmit... when you computed your position, and transmit this back to the robot does it take into account the latency on this end. How did you work around or simulate the FMS locked stress, and did you test against a typical network traffic of a match.
All of these questions scared me away from this kind of solution. I hope you have some good answers for them.
I guess you can always set still for a few seconds and that should solve that.
Unread 22-02-2012, 12:48
The short answer is that if we discover network latency/dropout to be a significant problem, we will move our image processing application to an onboard laptop. Failing that, our next fallback is to reduce resolution and/or framerate. To be frank, we auto target just fine at 5 fps (because the gyro loop is closed at 200Hz); we do 30 because we can
However, I do not expect this to be a major concern. In past seasons, teams have streamed live camera data directly to their dashboards with few problems. The only difference is now we are cutting out the cRIO altogether. While we haven't run simulations against an "FRC network simulator" (but if you know of a tool that could be used for this purpose I would be interested in trying it), in theory there is PLENTY of bandwidth to go around. With reasonable compression settings these images are only on the order of 10-20 kilobytes a piece.
We don't timestamp the images, but we do transmit our heading synchronously with new camera images being available. That way, the results returned by the vision application do not go "out of date" if they are received late. Out of order packets would be a bigger problem (it's UDP under the hood). But absolute worst case - like you said - this would be a transient problem and would straighten itself out within a second or two.
EDIT: Forgot to add, we also do low pass filtering of both outputs from the vision system to help smoothness (and to reject momentary disturbances like when we occlude the vision target with a flying basketball ). This should help with occasional frame drops as well.
Unread 22-02-2012, 13:02
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Clean looking machine!
It's nice to see another robot with a wide pickup! :-)
See you at Chestnut Hill!
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 22-02-2012, 14:21
waialua359's Avatar
waialua359 waialua359 is offline
AKA: Glenn
FRC #0359 (Hawaiian Kids)
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Nice job there Jared and Al!
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Unread 22-02-2012, 14:40
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Awesome. Can't wait to play with 341 at Hatboro-Horsham. I'd volunteer to use your opposite-loader, but I'm thinking we want to shoot our balls in auto.
Unread 22-02-2012, 15:06
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
What part number did you use for the optical photosensor / tachometer ?
Ed
Ed Barker
Unread 22-02-2012, 15:08
It is the Allen Bradley 42EF-D1MNAK-A2 from last years' Kit of Parts.
Unread 23-02-2012, 11:09
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Wonderful bot.
A couple of questions:
1> when your manipulator flips out it looks like it breaks the front plane of the bot in more than 1 location. Are you concerned that it might be ruled 2 appendeges?
2> when your manipulator is deployed it appears to obscure your numbers. Is that just the angle of the picture?
Otherwise, the bot looks gorgeous.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 23-02-2012, 14:26
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
I'm not sure why that would be a problem
Game - The Robot » Bumper Rules
Q. Can the bumpers be covered at any point by a dynamic appendage on the robot?
FRC1648 2012-01-14
A. There are no rules prohibiting this.
Unread 23-02-2012, 14:33
The entire thing is articulated as a single assembly. It is difficult to see from the photo, but there is a reinforcement bar all the way across the width of the bot right at the point where we cross the frame perimeter (on top of the bumper). We momentarily break the plane in two separate places during the act of deployment, but that has been explicitly allowed via Q&A and Team Updates.
As for numbers: from a full frontal view, you can actually read them just fine when your intake is deployed. The intake is mostly air
Unread 23-02-2012, 08:15
lynca's Avatar
Andrew Lynch
Thank you Jared and Team 341, do you have an upclose picture of your shooter and encoder setup ?
Unread 23-02-2012, 08:27
Here is a closeup of the shooter.
The sensor is on the left side of the picture, and two retroreflectors are mounted 180 degrees apart on one of the shooter wheels.
