Originally Posted by BrendanB
Very nice robot 2791! Jack, what is the range difference when the shooter hood is retracted and fully extended?
We're actually losing hood capability for BAE and CT. The hood was designed to make two pointers from the fender easier in case we weren't accurate enough at three pointers from the key. However, at the field we determined we are fairly accurate at threes, and the hood position had very little effect on how easy it is to make twos. By losing the hood, we can save almost 8 lbs for weight we can put down low. We like to tip a lot. :/
Originally Posted by JewishDan18
That's really cool! I assume the usage is too much to have a compressor that keeps up, or the weight of a compressor gives enough tanks to hold the air for one match. Can't wait to see you guys at BAE (and CT for that matter).
We don't have enough weight for the compressor and sufficient air storage. Also, We don't have the budget to purchase the new small compressor.
