Go to Post The code won't compile if you violate the rules of the programming language...but English is more robust, it seems to work pretty well no matter how we engineering nerds mangle it! - MrForbes [more]
Unread 05-03-2012, 17:39
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: pic: A Beautiful Mess?
I see a few issues here. The first is that you have 2 power converters, neither of which is hooked up to the regulated 12 volt output on the PDB. The wireless bridge should be run off of one of the 12 volt regulated supply via one of these adapters to avoid communication drop-outs. The second thing is that your compressor is connected directly to a hose after the check valve. after the check valve should be a tee with whatever you want on oneside, and the pressure relief valve on the other to satisfy [R75]
[R75]
The relief valve must be attached directly to the compressor or attached by suitable brass fittings connected to the compressor output port.
If necessary, teams are required to adjust the relief valve to release air at 125 psi. The valve may or may not have been calibrated prior to being supplied to teams.
