Go to Post These awards aren't easy to get, and if a team deserves an award, they deserve to be cheered on for it. - tckma [more]
Unread 06-03-2012, 18:34
V_Chip's Avatar
V_Chip V_Chip is offline
Back in action.
AKA: Victor
FRC #0175 (Buzz Robotics)
V_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud of
Re: pic: Brakes.. Deploy!
Originally Posted by Sb28000 View Post
Having a "brake" like that is an impressive idea! Is it pneumatic-powered, or driven by some motor? Also, why does 3451 have a blue bumper on half of its front side? I hope they built them sturdy enough to put up with that much weight applied to them!
Thank you!
The brakes are purely pneumatic.
Luckily 3451's bumpers were still intact, though we did leave an imprint.
Originally Posted by Jeffy View Post
What extra functionality do those "brakes" give you over the typical servo w/ pawl into the gearbox?
Our brake system guarantees that once deployed, we do not move AT ALL. Say if an alliance member went to double balance with us, we usually offer to be the immobile member of the balancing act. Once on the bridge, we plant our brakes. If unbalanced and tipped in our direction, the brakes guarantee that we do not slip and roll off.
Our current configuration of plaction tread wheels may have plenty of grab on the carpet, but are quite slippery on lexan. The pneumatic brakes have an insured non-slip grip pad on the bottom. If the brakes are down, we're not going anywhere.
Here are some of the pictures we took at BAE GSR.
http://buzzrobotics.org/node/193
There is a close up of our deployed brakes.
