Go to Post I think overcoming obstacles together builds a stronger team. - MissInformation [more]
Unread 11-03-2012, 16:40
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
paper: Heroes of Tomorrow - 2012 Tech Notes
Heroes of Tomorrow - 2012 Tech Notes by Adam Freeman
EDIT: Huh...this is interesting. I didn't think I opened a thread to start a discussion about the document. I was planning on posting a picture of the finished robot and linking to the document....but, I guess there will be pictures posted by Daniel Ernst from Waterford soon.
Couple of quick specs about the robot:
- Standard sheet metal chassis.
- 8WD - Supershifters. Window motor shifter.
- Fixed angle (45 degrees), non turreted shooter.
- Dual AM 9015 motors, custom 2.5:1 gearbox (~8000RPm).
- Utility Arm: For ball grabbing, loading, barrier traversal, and ramp balancing
- Double roller on top and bottom grab bar for game piece collection. Powered by (2) RS550 motors.
- Rear pivot and (2) RS550 motors, with huge amount (~760:1) reduction for arm movement.
- Camera Aim.
Unread 11-03-2012, 16:45
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
Re: paper: Heroes of Tomorrow - 2012 Tech Notes
Adam,
Thanks for posting this... this is an incredible insight into the process that led to one of the most creative designs I've seen yet this season. I don't think I would ever have ended up going this direction with my design, but yet once I saw your robot in action it was clear it was elegant and perfectly suited for the unique design challenges of this year's game. Congrats on your Waterford win, and another great machine!
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
Unread 11-03-2012, 17:54
Forever HOT!
Originally Posted by Jeff Waegelin View Post
Adam,
Thanks! That's funny...JVN told me almost the exact same thing. I guess all you Robowranglers think a like.
All the credit goes to our Chief Engineer, Jim Meyer. He knew immediately the need for a balancing aid. Combine that with the task to try to limit un-needed complexity and have robust components with more than one function, the robot just kinda took shape from there.
I kept saying that designing this arm is more like designing a tractor accessory than a FIRST robot component. It's definitely build to take some abuse.
The paper was inspired by 148, since you guys have done so much in the way of documenting your design process and build season. We once again attempted to have build season blog, but it ended up incomplete....(kinda stopped once the practice bot started running).
Anyway, I figured something should be put out there to document the process that went into this creation...especially since it appears to be a somewhat unique design.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 11-03-2012, 17:59
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Originally Posted by Adam Freeman View Post
*snip*
Adam, thank you for posting this.
Interestingly enough, after some friends and I saw a picture of your robot from Waterford and saw videos of it running we all kind of said 'How the hell do you come up with that.' Looks like our questions have been answered.
Unread 11-03-2012, 18:21
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
This is how you build a robot.
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 11-03-2012, 21:14
Excellence is Bliss
FRC #0111 (WildStang)
I'm sure that many teams out there are kicking themselves right now for not thinking of this.
This is possibly the greatest creation I've seen yet this season. Hats off to 67, your team is always setting the bar high. I only wish we were able to play with you guys. Maybe at the championship?
Unread 11-03-2012, 21:24
Aren_Hill's Avatar
Build Nifty Things
I'd like to issue my thanks for posting this, phenomenal integration and execution.
A guy who likes robots.
Unread 12-03-2012, 00:07
Legator91's Avatar
Legator91 Legator91 is offline
AKA: Ryan Legato
FRC #0067 (HOT Team)
Legator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud of
Send a message via AIM to Legator91
Sadly I wasn't able to make it to the competition this weekend, but I was watching video, or checking TBA all weekend to get updates.
I have to say the robot this year looks amazing Adam. You guys did a great job in design, and fabrication. All of us HOT alumni at Michigan tech were wondering just how everything worked on the bot this year, and the tech notes definitely explained it all.
Also, reading that brought back some great memories from my 2009/2010 build seasons at GM. I can definitely say the way we did stuff at HOT greatly reflects the engineering design process I am learning about in school.
Great job this weekend, and good luck for the rest of the season!
Michigan Tech: 2010 - 2014
University of Michigan: 2015 - Present
Mentor (FRC 67): 2015 - Present
Mentor (FRC 3771, 4363): 2011 - 2012
Student (FRC 67): 2007 - 2010
2010 World Champs (294, 67, 177)
2009 World Champs (111, 67, 971)
Unread 12-03-2012, 01:26
Drivencrazy's Avatar
Drivencrazy Drivencrazy is offline
AKA: Clint Ott
FRC #1011
Drivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant future
Very interesting read. I always enjoy looking into other teams approach to the design process. Thank you for posting this and congratulations on another great robot and a good win at Waterford!
Unread 12-03-2012, 13:27
klbarie's Avatar
klbarie klbarie is offline
AKA: Kyle Barie
no team (HOT Team)
klbarie is an unknown quantity at this point
Couldn't have said it better myself.
2009 - 2010: Team 67-The HOT Team-Student
2011: Team 3771-The Yooper Troopers-Mentor
2012: Team 4363-The Unbolted Puppeteers-Mentor
