Go to Post Ultrasonic sensors will allow you to do fundamentally the same thing that the bump sensors do...so you can slow down and smoothly stop your robot just before it reaches the end wall, instead of running into it at full speed and then figuring out "ohh! there is a wall there!" - dlavery [more]
Unread 12-03-2012, 12:29
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
pic: Heroes of Tomorrow 2012 - HOTBot
Unread 12-03-2012, 12:33
JABot67 JABot67 is offline
Unregistered User
AKA: John Bottenberg
FRC #2930 (Sonic Squirrels)
JABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond repute
Re: pic: Heroes of Tomorrow 2012 - HOTBot
Thought I might start a discussion on this. This thing is a beast. An absolute beast. I wish there was more video of it working so everyone could see how easy it is to balance the Coopertition bridge or triple balance when this robot is a factor.
Congrats for winning Waterford, HOT! You will go very very far this year with your completely unique robot. I could almost compare the advantage that this bridge utility arm gives to the advantage that 469 gave an alliance in 2010. Almost....
John Bottenberg - University of Michigan '14 - Microsoft
FLL Team "Dark Matter": 2003-2005
Robofest Team "Dark Matter": 2005-2008
Team 67 Programmer: 2007-2010
Team 3322 Programming Mentor: 2012-2014
Team 2930 Engineering Mentor: 2015-????
Unread 12-03-2012, 12:34
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Adam can you post pictures of how the arm collects the balls and how they are held in the arm?
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 12-03-2012, 12:38
Andrew Lawrence
This robot is one of the best things I've seen in my time in FIRST. Not only is thing a scoring BEAST, but it is also THE best bridge bot in Rebound Rumble. The CG is so low, that if this thing tips, I might as well disassemble our entire robot, because if 67 tips over wit this bot, we'll tip over with ours.
Beautiful machine 67! It's teams like HOT that inspire FIRSTers to make quality robots and innovate amazing designs like this one.
Unread 12-03-2012, 12:40
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
I am really interested to know how well that arm holds up throughout the competition season.
Did it take any hard impacts from other robots? What is it designed to take?
Also, what spares have you planned for it?
Very cool design.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 12-03-2012, 12:48
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
I would also like to see how you guys did this. Great robot as usual.
Unread 12-03-2012, 13:21
Forever HOT!
Nick,
The best I can do right now is link to our website photo album. There are a couple of good pictures that I think will show how the intake system works.
http://frcteam67.dyndns.org/HOTPhotoAlbum/index.html
Basically, it's similar to how teams picked up balls in 2010. The front roller grabs the ball and pulls it into the lower bar and the rear roller. This picks the ball off the ground, so we can continue to move around and collect balls. The rear roller is un-covered PVC which allows it to spin on the ball when the ball hits against the bumper. Both rollers are connected by round belting and are spun with a 550s (which also power the wheels on the arm).
The wheels are there for traversing the barrier and pushing up the ramp, if needed.
The arm rests on the gas struts that assist the motors and have been designed to have the wheels ride about 1/2" above the ground during normal operation.
When we lift the arm to dump into the hopper, the ball is pinched between the lower bar and the rear roller. This hold the balls until we spin the rollers to drop the ball into the hopper.
PM me if you want more detailed pictures, I can send you some screen shots of the design.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 12-03-2012, 13:57
Forever HOT!
Very cool design.
Jeff,
I also am interested to see how it holds up to abuse. I think it was designed pretty robust. Our process is more experience based guessing, than hard calculations. We had 2"x3" tubing ordered...it seemed like 2"x2" might not be enough...so we went with the bigger tubing.
The entire arm mounting is tied into the frame structure. The arm pivot is 2" diameter 1/16" wall tubing.
Since the entire arm and pivot are welded together, we have one spare arm which is fully assembled on our practice bot. We also have spares of all the attachment pieces and rollers components in case those become damaged.
The plan would be to attempt to repair the arm as much as possible if it gets bent up. If not, pull it off and replace it with the practice bot arm.
We didn't take any big hits at Waterford. Short of running it full speed into something, I am not that worried about it getting serverly damaged. The arm was designed to protect the rollers from taking an impact, with (2)-2" AL angle pieces placed in front of them....so, I feel ok with them being safe.
When the arm was initially welded, it flexed and ended up outside the 14" limit. We attempted to bend it back, with a chain, some huge pieces of steel, and some 200+lb engineers. After flexing over 3/4"...there was a huge "pop" and we broke the right elbow arm weld joint. We re-clamped the arm into the right position and re-welded it. We may gusset that joint, if matches start getting crazy.
Thanks for all the great comments!
