Thread Tools |
Rating:
Display Modes |
Re: pic: 3928 Swerve Module
I wish our students were around to answer your questions and explain all the work they did, but unfortunately most of them are way on a band trip.
- If you look, you'll see a plate above the turning gear. We attached that to our bellypan. - If I'm not mistaken, the plan was for about 360 degrees with a bit of overlap (so that there isn't a dead spot) (Aren might swoop in and correct me on this one). Quote:
![]() Last edited by Katie_UPS : 12-03-2012 at 15:47. |
Also, I don't see a steering angle sensor. Is it hiding in plain sight? |
The steering encoder (ma3 from usdigital) is mounted above the center of the module on the polycarb hoop into a 3d printed adapter, the body of it is held on another lexan bracket that reaches from the side of the frame over the top of the module. |
A CIM as a bearing, just a beautiful and awesome idea and design.
Please tell me you're going to mass-produce this and sell them! This is probably the best/smallest swerve out there! Any videos?
So what goes in between the CIM and the colson? And did the colson come with that big of a bore or did you have to bore it out you're self's?
that sleeve is what i got to use a 2.5" drill bit on here are more pictures: http://www.chiefdelphi.com/media/photos/37675? http://www.chiefdelphi.com/media/photos/37674 http://www.chiefdelphi.com/media/photos/37673 Last edited by Aren_Hill : 12-03-2012 at 19:49. |
That swerve is all kinds of awesome. Great work 3928.
#10
This is the kind of thing that my math and spanish spirals are filled with! who needs education when you haave First?
i thought about this once, but rejected it as insane. props to you for making it happen |
#11
This is amazing. That is all I have to say.
Sad thing is I just started thinking on how to improve on what I have seen recently in crabs and swerves. I now have to think harder. Challenge Accepted. - Andrew |
#12
How are the stress loads of robot movement transferred between the wheel and frame? What kinds of stress testing has this module undergone? Finally, is it possible for extreme heat from CIM abuse to transfer through the steel/aluminum and warp the plastic beaings over the course of a competition?
Am I the only one who really likes the tensioner that mounts directly to the rotatable CIM? The overall concept seems a bit high risk/reward to me, but the little things that make it more compact are the real genius of the design IMO. |
