Go to Post FIRSTers in particular want very strictly delineated guidelines so that they know exactly what parameters under which they're working, except when they don't. - pfreivald [more]
Unread 12-03-2012, 19:42
crazyStone crazyStone is offline
Cad posessed
AKA: Derek Stone
no team (Charger Robotics)
crazyStone has a spectacular aura aboutcrazyStone has a spectacular aura aboutcrazyStone has a spectacular aura about
Re: pic: Final Render 2012
Originally Posted by Navid Shafa View Post
I'm not sure if you noticed, but half of your wheels and lower part of your drive base is cut off due to the ground plane. I recommend constraining everything independent of the ground plane. After you add the wheels, tangent constrain them to the ground plane with an offset for more visual appeal and less "robot loss".
The ground plane is actually 1/2" below the wheels, due the physical configuration of our robot you can't see them and the reason you see the reflection is that it's a shiny ground plane. If the bottom of the drivetrain were cut off you wouldn't be able to see the full reflection of the wheels etc.
Ahh the infamous team numbers, we have a very good person on our team in charge of graphics, and the issue is, our team number is "mountain dew" font, somehow years ago they got it. Anyhow the graphics person said we could only use that font, and it's saved in a particular image style and when I went to import it into the sketch the transparent background surrounding the letters is turning gray, and they will not allow me to use any other font in native autodesk to emboss the number. And hence why there are no team numbers, currently.
