Go to Post OK guys, the robot's overweight. You know the drill. - DonRotolo [more]
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Unread 13-03-2012, 00:47
Andrew Remmers's Avatar
AKA: Andrew Remmers
Re: pic: 3928 Swerve Module
This is amazing. That is all I have to say.
Sad thing is I just started thinking on how to improve on what I have seen recently in crabs and swerves.
I now have to think harder.
Challenge Accepted.
- Andrew
Exploding Bacon 2007-2011
Unread 13-03-2012, 09:50
How are the stress loads of robot movement transferred between the wheel and frame? What kinds of stress testing has this module undergone? Finally, is it possible for extreme heat from CIM abuse to transfer through the steel/aluminum and warp the plastic beaings over the course of a competition?
Am I the only one who really likes the tensioner that mounts directly to the rotatable CIM? The overall concept seems a bit high risk/reward to me, but the little things that make it more compact are the real genius of the design IMO.
GitHub
Unread 13-03-2012, 09:57
Andrew Lawrence
I don't think they come any compacter than this. BUT, I want to see it run a whole season before I go out trying to replicate it. While it is small, how small is "too small"? Aside from this rare occasion when the OP says they need that tight of a space for a swerve, I don't see this being put into any real use unless they prove this season that it not only works great, but is advantageous to the user.
Nonetheless, I still want one.
Unread 13-03-2012, 10:14
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is online now
AKA: Sean
FRC #2415 (Wired Cats)
How does the smallness of a solution coorelate to the usefulness of it? When this whole competition is about how much function you can fit in a give size and weight constraint every bit counts. They are using the same axial bearing set up as 16, a team who has IMO perfected swerve drivetrains in FIRST. They are also using an axle for the wheel that is effectively 2.5" diameter. Much larger than the majority of teams. Additionally this isn't Arens first foray into swerve drivetrains.
Mentor 2415
