Go to Post Seniors, do you realize this is your last robot season?! - atomikitten [more]
Unread 14-03-2012, 23:42
kevincrispie's Avatar
FRC #0971 (Spartan Robotics)
Re: pic: FRC971 Spartan Robotics Presents: Renegade
Here's a link to Austin's post last year regarding the fans.
http://www.chiefdelphi.com/forums/sh...8&postcount=18
When turnaround time is faster during matches (practice rounds, elims, etc) the fans have their largest effect.
Unread 14-03-2012, 23:55
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Originally Posted by Nuttyman54 View Post
Thanks for the compliments Akash, the team is really proud of this one. This is the best picture of the transmission I could dig up is here.
Wow, that's a well done transmission! How did you mount the two gears to the CIM? Did you use the AM 8mm to Hex adapters, or broach your own gears? That's certainly a elegant way to get shifting with minimal complexity. By the way, are the center wheels direct driven?
-Plutarch
Unread 14-03-2012, 23:57
Andrew Lawrence
How does the belt drive work for you? Was it hard to do? If so, was it worth the difficulty?
Unread 15-03-2012, 00:05
We'll see how it holds up at Davis. It has been working pretty well thus far after the drivetrain was tuned.
The timing belt drivetrain is nice, but it's best to run force calculations to see how it'll hold up. Belt doesn't stretch like chain does, and its quieter and a bit more efficient. It is also lighter. This, coupled with the fact that we have 2 inch wheel means we should be able to get to where we want to go on the field.
The extra traction is useful going up the bridge.
Unread 15-03-2012, 00:25
3. Any issues with balls jamming in the hopper/conveyor?
I think you realized this already, but we put in a horizontal conveyer to help sort the balls. Since we were going with ~24 in intake, we needed a way to rapidly get the balls into a column/row/whatever. Once organized, we can pretty easily get the balls into the tower. The vertical belt then runs at the same time as the shooter wheel, and presto, we shoot (and hopefully score).
Below is a picture of the conveyor.
The team spent several days prototyping this. Inevitably, a ball would get stuck somewhere. We configured it with the intake, then make sure we had accurate measurements in the CAD that were the same as the working prototype. Since it was such a key part of our game, we spent a lot of time on this.
Unread 15-03-2012, 07:42
James Kuszmaul James Kuszmaul is offline
NEFIRST CSA
James Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud of
We got a shaft custom machined to press onto the CIMs.
The transmission assembly is detachable, and it outputs in a 15 tooth gear which meshes with a 50 tooth gear which is on the same axle as the center wheel.
FRC971 (Student) 2011-2014
FRC190 (College Mentor-ish) 2014
WPILib Development 2014-present
Unread 15-03-2012, 08:35
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Another awesome machine!
As always you guys play so fast, its amazing. I am sure your drivers will be practiced up and ready to go.
I really like the horizontal belt system to push the balls over and line them up. Really cool way of solving the jamming problem.
I am really happy to see you are registered for the Championships this year. You had such a great robot last year, I think it would have been a big factor in the elims if you could have qualified for Champs.
Good luck this weekend.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 15-03-2012, 08:58
nlknauss's Avatar
nlknauss nlknauss is offline
STechnologyEM Teacher, Alumni
AKA: Nate Knauss
FRC #2729 (LC Storm Robotics Team)
nlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond repute
Great looking robot and design process you all seemed to follow. After seeing this robot and others from CA it makes me want to take a trip out to visit the regionals sometime. Thank you for sharing the details of your machine with us! Good luck in competition.
Nate
Nate Knauss
FRC 2729 Teacher-Drive Coach 2009-?, FTC 4390, FTC 7433
FRC 87 Student 2000-2002 and Mentor 2003-2006, FRC 1647 Mentor 2006-2008, FIRST Senior Mentor 2009-2013
"We can't change the cards we are dealt, just how we play the hand." -Randy Pausch
Unread 16-03-2012, 09:35
Sh1ine Sh1ine is offline
FRC #2791
Originally Posted by kevincrispie View Post
We also worked to make new wheels this season, to complement the new drivetrain.
Tread is attached via zipties.
Wheels measure around 2 inch wide and 3.5 inch tall w/ tread.
Thank you to RC for machining these. They turned out great (so far).
Very nice robot.
We also use belts for our drive train. This is our second year using them and as for a a skid steer type drive train is concerned I do not think we will ever go back. We use live axles in our system. It seems like you are using a dead axle system with the sprockets machined directly into your wheels (very cool). I would love to see a up close and personal view of how your power transmission works.
Unread 18-03-2012, 16:57
Excellence is Bliss
FRC #0111 (WildStang)
First of all, Congrats on the win at Sacramento. I'm glad to see you guys coming to the championship this year. I really wish I had seen 971 at St. Louis last year.
Second, I'm curious about the pistons you're using to shift. I've never seen anything like that! How reliable are the "Pancake" pistons? Are there any drawbacks to using them, compared to the standard actuator on an AM supershifter? It looks like they save quite a bit of space and weight. Also, where are they for sale?
Unread 18-03-2012, 17:02
ttldomination's Avatar
Sunny
The recent driver practices have shown the robot works excellently! 971 is going to be a strong contender at SAC and SVR. IMO It will win them both, as the alliance captain.
http://www.youtube.com/watch?v=KS3n9...6fFAAAAAAAAOAA
http://www.youtube.com/watch?v=rK2et...47FAAAAAAAAPAA
Vids are private?
Would love to see this thing in action.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 18-03-2012, 17:10
Andrew Lawrence
Originally Posted by ttldomination View Post
Vids are private?
- Sunny G.
I just found them on youtube one day while searching for robot things, and they were public then. Looks like they're private now.
You can probably find videos of the robot in matches at the SAC regional on youtube, or from the SAC regional thread, where someone may have posted links.
Unread 18-03-2012, 17:18
I can talk to people to see if we can get some videos back up. We hope to make some sort of video compilation to send out.
Stay tuned.
Unread 18-03-2012, 17:38
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
We first used the pancake cylinders in 2010, with the 3 position variety for our PTO, due to the relaxed pneumatic rules. I believe we were the first team to use the flat cylinder line from Bimba.
We used the 2 position ones last year and this year.
They're no more or less reliable than the standard Bimba line of cylinders. They do require different fittings, since they are so small, and must be face mounted.
2001-2004: Team 100
2006-Present: Team 254
Unread 18-03-2012, 17:48
Excellence is Bliss
Thank you for the information! Do you know the part numbers for the cylinders and the fittings offhand?
